Just check what this Gigachad did![]()
You mean this?
https://groupdiy.com/threads/where-does-the-tone-come-from-in-a-microphone.85257/
Not that it had much (or anything) to do with this particular thread in the first place, anyway...
Sorry my bad. I was on the page DIY condenser mics and wanted to post this - but I guess I made a mistake and posted in RF mics.Does it have anything to do with RF mics?
Happens all the time. Welcome!Sorry my bad. I was on the page DIY condenser mics and wanted to post this - but I guess I made a mistake and posted in RF mics.
The video is about testing lots of mics and their frequency response so I hoped it will help someone.
(My first post and it wrong- I will watch out in future)
It suggest increasing the number of turns by a factor ca. 1.5 for the windings that are connected to the capsule.I think the next step might be to try and work out the kind of coil winding details that would be needed to work well with capsules of significantly lower capacitive values... Say in the range of 35pF to 50pF?
A quick calculation suggests they're likely to need inductances in the 15uH to 20uH range, to keep the oscillator values at a sensible frequency ?....
That's quite a lot higher than we're currently getting. How easy that would be to obtain with these coil formers, I'm not sure?.....
First of all, thanks for your great job. Very interesting and instructive.[...]
Peter Baxandall - whose 1963 WW article I posted here: https://www.jp137.com/lts/Baxandall.RF.mic.pdf - lists the reasons he abandoned FM for this type of project on the first page of that paper. It' s so difficult to keep the oscillator noise levels low, when using simple FM transmitters.First of all, thanks for your great job. Very interesting and instructive.
Regarding the problem of adapting the transformer to the capacitance of the capsule due to the fixed frequency chosen, why not replace the oscillator circuit with a simpler one without a crystal where the oscillation frequency was determined by the bridge capacitance and the inductance of the transformer? Thus its frequency would naturally follow the changes in capacitance of the different capsules.
This change would allow also removing the second transformer (some rf chokes needed).
Simulating this change in LTSPice doesn't look bad (attached test asc file), but I don't know if noise (oscillator AM noise) can be the real problem here. Or maybe the simulation model is not correct (anyway, I haven't build this circuit).
I have not said nothing about FM, I only suggested a different oscillator without a crystal, as Baxandall and Arends before did; I follow the simplest way, why fixing the frequency if we are not interested in frequency? The transformer and the capacitor bridge is a tuned LC tanq, let it oscillate, a crystal is not needed. Anyway, not FM demodulation, just to be clear.Peter Baxandall - whose 1963 WW article I posted here: https://www.jp137.com/lts/Baxandall.RF.mic.pdf - lists the reasons he abandoned FM for this type of project on the first page of that paper. It' s so difficult to keep the oscillator noise levels low, when using simple FM transmitters.
As you can read, Baxandall decided to move to an AM system (as did Sennheiser in the 1980s - some history on that here: https://assets.sennheiser.com/global-downloads/file/11061/MKH-Story_WhitePaper_en.pdf )
Another important observation from Baxandall is the capaitance shifts we are dealing with here.
From his paper: "Ordinary conversational speech at a foot or two corresponds to about 1 dyne/cm² alternating pressure, and this
causes, with a typical modern electrostatic microphone element, a capacitance change in the region of 0.001 pF..."
These are tiny changes..... we need all the help we can get in boosting those signals to usable levels, without being swamped with noise in the following amplification process necessary. Hence the use of a high 'Q' tuned inductor/ capacitor combination from the second transformer.
(High Q tuned circuits effectively allow for some 'noise free' gain ! )
It may be possible to try out alternatives... my project is only one experimental offering -- but I have tried both FM and AM with no second transformer, and have never got near to producing anything that wasn't unacceptably noisy.
You mention 'LT Spice'.... I'm not sure that kind of simulation software is much use in this type of project? ... there are simply too many unknowns in the inductor asembly construction for this type of software to produce anything accurate.
One of our most senior members - Abbey road d'enfer - tried some inductor assembly simulations earlier on in this thread
(round about post #257) . Some interesting results, but not very close to the 'real world' versions currently being tried at that time.
Comments about the theoretical aspects of this particular type of inductor assembly on other expert RF forums tend to bring about the same type of response ... too many unknowns to make an accurate 'simulation'
So up to the present it has just been a 'let's try this next' type of project ... Ideal for a hobby mic forum of course!
Be interesting to see if your 'simulations' help to create an alternative arrangement.
Could be you come up with an effective simple FM system that doesn't have too much oscillator noise, and doesn't need high 'Q' tuned inductors, and prove us all wrong!![]()
My apologies - I had read your comment "... where the oscillation frequency was determined by the bridge capacitance" as meaning FM........my mistake.I have not said nothing about FM, I only suggested a different oscillator without a crystal, as Baxandall and Arends before did; I follow the simplest way, why fixing the frequency if we are not interested in frequency? The transformer and the capacitor bridge is a tuned LC tanq, let it oscillate, a crystal is not needed. Anyway, not FM demodulation, just to be clear.
Bridge imbalance is only essential for cardioid and omni patterns The 'figure of 8' configuration works well with a fully balanced bridge!That's exactly what I wanted to say. Both rogs' original and ricm's proposal use bridge unbalance for detection, which is some kind of FM-in-reverse, where the carrier is fixed and the detector varies..
That's not what my simulation shows.Bridge imbalance is only essential for cardioid and omni patterns The 'figure of 8' configuration works well with a fully balanced bridge!
That's exactly how I see it, but the rectifier produces an output voltage that is proportioal to the absolute amplitude (although with an offset), so whatever teh deviation, an imbalance always results in a positive output.The output taken from the centre point of the bridge to the second transformer acts rather like the 'wiper' of a 'capacitive potentiometer'.
I agree, but the notion of "reversed polarity" must be more defined. The output is always positive, even when the stimulus goes negative.For both omni and cardioid that 'wiper' must not be allowed to pass throgh the balance 'centre point' - or the signal reverses polarity.
That's not what I see - again in simulation.That limitation does not apply to the fig.of 8 option. It's the centre point that shifts in that configuration. So no polarity reversal.
I must check my experimental results again ... As I recall, the polarity of the output signal depended on whether the capsule capacitance value was greater than or smaller than the bridge balance capacitor (C4).That's not what my simulation shows.
With teh bridge balanced, i.e. both caps equal, any variation in either way results in the same positive output voltage.
You may have experienced differently because in a practical implementation it is impossible to have both sides having equal capacitance.
Seems to me it's in contradiction with your post #593: "For both omni and cardioid that 'wiper' must not be allowed to pass through the balance 'centre point' - or the signal reverses polarity."I must check my experimental results again ... As I recall, the polarity of the output signal depended on whether the capsule capacitance value was greater than or smaller than the bridge balance capacitor (C4).
You must be right of course -- in the case of fig-8 both 'bridge' capacitors are the capsule. If they both change capacitive value by exactly the same amount then the value of the total bridge capacitance would remain the same, and the carrier amplitude wouldn't vary.Seems to me it's in contradiction with your post #593: "For both omni and cardioid that 'wiper' must not be allowed to pass through the balance 'centre point' - or the signal reverses polarity."
It implies that when the displacement exceeds a certain value - where the output is null - the polarity reverses. This is characteristic of a rectification.
It makes sense since AM detection is sensitive to the absolute amplitude. It means that the output signal is an image of the RF signal's amplitude.
In these conditions, the native fig-8 capsule would also result in "rectified" output.
Your experimental results probably show that there is a hidden detection process happening. Maybe it's simply the fact that both sides of a native fig-8 capsule are never strictly identical. The difference may be negligible, it's still much higher than the pressure-related deviation in normal conditions.
In this system the JFET is being used as a self biased infinite impedance detector, which is essentially a non-linear funtion that detects changes in RF carrier amplitude.I wonder whether, rather than relying on bridge imbalance, it would be possible to add (a little bit of) the oscillator output to the the T2 output, so the FET gets the (vector) sum of the two. So when the bridge is one side of the balance point, they add in phase, and when it's the other side, it will partially cancel.
