jacobsteel
Member
I built a tape delay out of a TEAC cassette deck.
Introduction
DIY tape decks from 3-head (erase-rec-play) are common. However, the gap from rec-to-play only gives short delay times, even at very low (and lofi) tape speeds. I wanted longer delay times. Also, 2 head decks are cheaper.
The best candidates are older 2-head decks with separate rec/play switches. Top loaded machines are easier to work with. One section of the rec/play amp becomes record, the other play. You can easily disable one side of the mechanical arm for rec/play - should you ever later want to restore the tape deck.
In my version I also added a small audio transformer in the feedback (play section RCA out to record section in), as there was some direct leakage otherwise.
An extra bonus is I can also add pedals in the feedback loop. I now have a simple Behringer limiter and an EQ for infinite feedback without distortion (well, it's not Hifi, but the distorsion is controlled).
Build
1. Heads: Two mono heads mounted side by side replace the old stereo head. The first (leftmost) head records (soldered to "Left"), the second (rightmost) heads plays back (soldered to "Right")
2. Tape: The Cassette tape is modified to accomodate two heads, add some foam to ensure that the tape stays close to the heads. I tried loops but ended up using a long tape and rewinding it (lasts longer).
3. Speed: The capstan motor speed control is moved to a potentiometer on the front.
4. Input: The tape deck mike amplifier is used for input just as it is.
5. Output: Taken via the headphone jack on the front: Left side direct signal, Right side delayed signal.
Discussion
The first trick was aligning the mono heads properly, not only to each other but to the tape. The second trick was modifying a cassette tape to apply enough pressure to the two heads. I tried modifying the cassette's standard copper-spring, adding a second foam cushion but in the end just cutting coam (from a detergent sponge) worked better.
> Link you Youtube build description
> Longer sound demonstration (piano)
I also added a CV control for tape speed.
> Youtube demonstration of the CV control.
![DIY tape deck.jpg DIY tape deck.jpg](https://cdn.imagearchive.com/groupdiy/data/attachments/60/60831-5a00f9a3f7fbf541c0f8849a99ae66d4.jpg)
Introduction
Build
Discussion
