peter purpose
Everything is ordered, so let's start with a BOM.
http://lazpro.com/eqnbom.pdf
I think it's all there.
Dang.....peter purpose said:Sorry girls, but I couldn't NOT share.
Skylar has rendered up a front panel with some custom knobs.... and I had to knock one out.
canidoit said:Were we meant to get some small resistors?
No.... resistors are down to you.
Are the rocker switches, the two little switches in the kit you sent?
Oh dear...I have an awful feeling.
On your BOM, if it does not have the voltage or wattage written on the components, what are the recommended minimum. Like on some of the capacitors, it does not state the voltage size and the resistors does not state the wattage.
1/4 watt unless specified for the resistors. Power caps need to be 25v minimum.
Will there be any wiring or special style of build process involved in this build? I can see that the 3 little pots are wired from one of your pics. How is the wiring on this build?
I'll stick up some diagrams...don't panic.
Can you please post up an eagle eye view top and bottom, nice and close and clear of the final finished build for visual reference.
Ahhh....That's how I started too.
Will this unit need to be calibrated in some way like the 1176?
It will
Here is a pic of my kit that I received. Anyone notice anything missing on it?
Jayzus Manny.... Check the thread in the white market. The kit contents are noted.
canidoit said:I am missing these 8X .8MM SOCKETS FOR CC-6** * in my kit by the looks of it.
canidoit said:---------------------------------------------------------------------------
(not written in March BOM - eqnbom.pdf)
I for one am quite offended by such language Peter. I actually think I want my money back for these 1084's. ???peter purpose said:What the fuck are you on about? It's at the bottom.
