Freed Transformer numbers
Walter66
Hello,
old Freed audio signal transformers often had just printed Numbers instead of other designations on the transformers.
Unfortunately, they had no data other than that number stamped on it. No pin designations, no values of coils, no impedances.
Is there any known source where those numbers and their connections to technical data is listed on the web?
Those numbers may be military speced and could be alternative designations for real catalog numbers. But even Freed transformer catalogs are hard to find now on open sources.
http://www.bunkerofdoom.com/xfm/
I contacted this company, which seem to be the successor to Freed transformers, but no answer from them to my request.
http://electronictransformercorp.com/
Maybe someone can give a hint where to start searching? Thank you.
Thank you! The era is post- war transformers, maybe up to 1960's. They have five digit numbers stamped on it. No catalog numbers from "The MASTER" will match them, Surplus sales don't list those types either.
