Yes, you can. This will work.Can I simply remove the back diaphragm polarization?
This may be of some help:Hi Guys,
I'm planning to build Oliver Archut's alternate M49 schematic.
I want to build the mic for cardioid only. Can I simply remove the back diaphragm polarization?
Interesting reading!
“The theory of none voltage difference at cardiode setting sounds great but the reality is that 60V (backplate) vs. 60V (back-membrane) will still push against and repell, displacing the membrane and changing overall the sound pick up.”
How and why, i wonder? And push/repel against what? The rear diaphragm and the backplate?
currently planning to make 2 floating points for the capsules hi-z connections.
Sorry but I'm not following...Why two?
I think Khron is telling you that you only need one high impedance floating point (isolated turret) because we are talking about impedances and that means alternating current. For AC, the capsule side of the C2 capacitor is more or less at ground potential because the capacitor is a frequency dependent resistor (or conductor). Ergo, you only have a high impedance point. Right or wrong?The tube grid is indeed a high-impedance node, but how and why is the other side of the capsule ALSO a high-impedance node?
Remember how capacitors work? They block what, and allow what to (virtually) pass through?
The more I think about my (and Khron's) explanation, the more uncertain I become, because if you look at it that way, then the grid of the tube would AC wise also be on ground potential, since the capsule is actually also a capacitor.Right or wrong?
I'll have to think about that now, I think I'll take a hot bath, that helps! Ahoy!It technically sort of pretty much already is, via the grid resistorBut not through the capsule itself, because the capsule CREATES the signal, rather than shunting it away from elsewhere.
..... Right..?![]()
I think it's worth treating it as a high impedance point since the capacitor creates a frequency-dependent "pass-through" for AC. If you lower the impedance to the backplate due to some circuitboard impedance or contamination, you would also effect the frequency of the RC filtration of C2. There's a reason R5 is 100M and not just 1M.
No disagreement there. Just saying that with the parts selection as-is, there would be no issue with making the R5/C2/Backplate junction hi-z and calling it a day.Make it 10uF then, and then you can reduce the resistor to 100k, to get the same 0.16Hz turnover frequency.Same thing, it's a bog-standard RC filter, no voodoo-magic going on there.
R5's 100Meg in order to achieve good filtering with "just" the 10nF of C5 (physically smaller and more long-lived than an electrolytic, and to not have the grid resistor as the only 100Meg on the bill-of-materials).
