amplexus
Ok so I'm far enough along now that I wanted to put this out into the world. I've been working on these original AU300 tube preamp modules for over a year now for a client who's gone down the rabbit hole- going to far as to have a metal shop fabricate replica sleds so we can build multiple variations of transformer combos that he can swap in and out. He has the original 8 slot rack, the original tube regulated PSU, and I built him a full XLR IO panel, and a control panel with PEC pots, and stepped pads, and input impedance switching on the most expensive greyhills he could buy (customer supplied all the parts... he's _particular_) to give him all the options of the original transformers. Additionally to that he has had 10 sleds fabricated, and even went to an auto paint supplier and had mica blue paint blended and matched exactly to the original McCurdy colour. Suffice it to say that I've become pretty familiar with this circuit and it's construction. So I thought- man these are great sounding amps, why has no one cloned them? I can't swear no one has, but I suspect being that they're Canadian and rather rare to begin with has a lot to do with it. I also know in the past Doug Williams has expressed a lack of love for them- maybe that's scared people off
So 3 ish months ago I started developing the idea to put together a PCB kit and BOM. Carnhill makes a suitable output transformer that I had already used in some of his builds with great success- comparing favourably sonically to the originals- but we had only been using vintage hammond, UTC and Triad transformers on the input as he could find on ebay etc... So i got in touch with Cinemag, as they had a transformer that was close to the right spec- but i needed a centre tap brought out on the secondary. They were extremely accommodating and custom wound and shipped me four units to check out. Over the last few days I've been building up one of the prototype PCB's and power supply PCBs and finally got to basic functional testing last night and they came out beautifully. Very quiet even completely outside any sort of shielded environment, even a bit quieter than the originals. ~45dB up to ~68db of gain (~25db with that will be the supplied input pad), push-pull topology across 3 tubes (2 x 12AX7 1 x 12AU7 driver). At any rate- I'm very happy with how these have turned out at this prototype stage, so I thought I'd put them out in a thread for discussion/opinions/thoughts and to gauge interest in a possible PCB set offering. Ultimately I would like to throw them up as PCB kits, or potentially full kits in the White Market- but they're not quite ready for primetime yet, and I'm still waiting for some clarification on a couple things re: white market membership/procedures/rules. I have a few things on the wishlist to work out for the revision. On the to-do list:
Originals in the original rack
Original tube regulated PSU after refurb. Needed to be gutted- all the wiring insulation was cracked and many of the resistors burned.
The originals post-refurb/phantom/pad/impedance installation:
My hastily constructed test jig last night on the new prototypes:
The PSU prototype:
And the original schematic:
- Shrink the footprint - I had originally laid this out for CDE 150/Vishay MKT1813 caps, but the Panasonic ECQ's sound great and the smaller footprint and lower price is nice, so I think i'll save space on the board
- Need to see if Cinemag will do the same transformer for me but with PC pins instead of flying leads so it can be PCB mounted. If not, I have also tested the Carnhill DI transformer wired backwards and it works great as well and is already a PC pin design. Either way, I need to adapt the layout for a board mounted transformer once i know what the options are
- Might tweak some values to alter the first stage gain- with hot sources it tends to saturate pretty fast. The input pad helps but it would be nice to be able to hit the input transformer a little harder if desired. Also might consider moving the input pad post-transformer
- The current prototype PSU is a 317 based reg for the heaters. It's enough current for 3 channels with sufficient heat sinking, but i'ld like to at least be able to provide for up to 8ch like the original supply. I've seen a schematic using a BUZ11 as a pass xistor that should be good for 5-6A
- Need to get all the various boards together (IO PCB, Main PCB, Pad/Phase PCB, output attenuator PCB, and possible gainswitch PCB if there's interest over a pot) and get a complete BOM assembled
- If i do ultimately put these on the White Market I'll be doing heavier copper layers (2oz), ENIG pads, and will probably do all the PCB's in black or red and in 2MM board if the cost isn't silly.
- May also tweak the connections. I thought about doing card edge and having a single connection point, but thinking about layout inside an enclosure I figured having the euroblocks on either end would shorten wiring runs a bit.
The PSU prototype:
