vintagelove
- Joined
- Oct 26, 2013
- Messages
- 161
Do you have a website etc for your services? Might be handy for the future. Either way it was good of you to help him out.FYI His unit has been repaired and returned to him with a chunk of the mod removed, along with some of our own fixes added. I will let him comment further. His was originally modded by CC&E, not used/checked upon return, then later was found to not function properly at all.
We adjusted the heater voltage to 6 volts (it was still stock). We moved the filament voltage regulator to the chassis so it could cool itself (they run SUPER HOT in stock configuration/location). We moved the Lundahl transformer included in this mod to a better/closer location - and further from the power supply. We fixed everything that did not work (instrument level input, high eq), and got signal to pass properly. Mounts were made for V5, and for the T4b, which was just flopping around on a board. (we have also since designed our own boards which incorporate legs to properly support the T4b.
Anywho - it behaves like a 610 now, rather than a doorstop.
