Studio Mollan
- Joined
- Oct 26, 2011
- Messages
- 323
New lower price on kits / pcb's, and no more built units.
The TIRDI-500 full kits are now 160€ plus shipping.TIRDI-500 PCB (including 4 knobs and front panels) 50€.
PROTO-500, prices lowered.
All payment is done via Paypal. Send me a message with your adress and I'll get back with an accurate shipping quote,
_____________________________________________________________________________________
Fellow gear / music enthusiasts,
Introducing the TIRDI-500 and the PROTO-500
![TIRDI-500 TIRDI-500](https://cdn.imagearchive.com/groupdiy/data/attachments/40/40391-c79d1745ae1f5a2d9d8b15346039dcf7.jpg)
![PROTO-500 PROTO-500](https://cdn.imagearchive.com/groupdiy/data/attachments/40/40392-f257d19127f2a5efacd38c0fddfd6a17.jpg)
Both units are made completely of PCB, circuit board material. The difference in color in the above pictures is due to the fact that the TIRDI has a top coat of polyurethane clear coat.
I had great help with the design from this forum so offering them here makes great sense. I’m also glad to pay a fee for the white market to give something back to the forum.
This is not a business venture for me so don’t expect this thread to be around for very long. I have a limited supply of full kits for TIRDI-500, but a larger supply of boards. As long as I have parts and boards available, and people are buying them, I’ll keep the shop open.
As you all probably know by now the availability on components are rough… I managed to buy a larger batch for 50 units before the pandemic hit the electronics supply. Almost all IC:s and capacitors I ordered from Mouser are now out of stock. That being said, it is not impossible to get more. Banzai still seems to have a good stock. If you want to source your own components it should be manageable. A lot of you guys probably have a lot of it already.
The PROTO-500 is just a set of circuit boards so that will be no problem at all to keep available.
TIRDI-500
Just a short introduction here. More info in the build manual. <- click link do download. It's a large pdf. Detailed photos -> large size.
EDIT: I added a short clip to my YouTube channel.
So:
TIRDI = Transformer Isolated Reamp + Direct Interface.
![TIRDI-500 side TIRDI-500 side](https://cdn.imagearchive.com/groupdiy/data/attachments/40/40394-c36c36d5d4eb4631b5506cd8af2cd805.jpg)
![TIRID-500 front TIRID-500 front](https://cdn.imagearchive.com/groupdiy/data/attachments/40/40395-823f1f45af4ae8b8792e4223406cf7e9.jpg)
It is a transformer isolated reamp device and a Hi-Z "DI" interface with filters. Use it to interface Hi-Z gear when recording or as a classic reamp device when, well.., reamping. Filters are resonant with large range.
I record and mix through a lot of such gear and this design started out to fill a personal need. I got some interest from friends and fellow GroupDIY:ers so I figured I might as well offer a few for sale.
I've tried to make the build as robust, easy, straightforward as possible. There is no calibration required, few electrolytic caps to get low maintenance, good quality components and still relatively Cheap. The component count is pretty low and all parts for the kits are VERY well organised. An experienced builder could probably build one in an hour.
I have learnt a lot from build manuals, and building kits, in the past so I made an effort trying to make this manual as informative as possible. I've gotten good feedback from all that has built and used the unit so hopefully this should all go very well. If this is your first kit, it should NOT be a problem. Please read through the build manual before your order though.
Price and how to order:
160€
50€, PCBs, no components. This includes the front panel. You need to order your own components. Check BOM in the Build Manual.
4 x knobs for the pots will be included while my stock lasts.
contact[at]studiomollan com. <- Get with me here, or send me a message here on groupdiy for orders. Include your forum name and adress / location for shipping price.
Here's the build thread. - > Build Thread
PROTO-500
![PROTO-500 side PROTO-500 side](https://cdn.imagearchive.com/groupdiy/data/attachments/40/40396-0b36cc8f7f390bd2a3e19eae378bb1a3.jpg)
![2022-01-10 16.28.26.jpg 2022-01-10 16.28.26.jpg](https://cdn.imagearchive.com/groupdiy/data/attachments/40/40392-f257d19127f2a5efacd38c0fddfd6a17.jpg)
A handy prototyping board. The pads are organised so you can pretty easily build a basic circuit with standard 8pin ICs. Up to 16pin works fine. As stated earlier it's all made of circuit board material, and you solder it together. It forms a tough connection and the unit is very sturdy when built. The front panel is all blank. Drill up whatever holes you want.
A user case could be this:
Get a JLM Amphead and mount it in the PROTO-500. A cheap, and good sounding 500-series headphone amp for very little $. Here you can also experiment with mono options, or individual mutes for "Left" / "Right" etc etc. Just what a prototype board is intended to be used for.
Or:
Get a couple of small VU-meters. Build a proper drive circuit for them on the PROTO-500 and install the VUs in the front panel. Easy and cheap way to add a patchable VU meter to your rig.
Or:
Fit a couple of panel voltage / current meters and fit them to the board. A neat way to monitor the PSU in your 500 rack.
Or:
Design, and build your own 500-series module.
_______
The board is pretty self explanatory. ALL connector tabs (ex +16V BUS, +48V BUS etc. etc) should be soldered together as a start. This makes the voltages and ground follow the lines on the board. This way the power is never far away and can easily be jumped over to the circuits.
"GND"
When bridged connects the metal in the front panel to ground. Could be useful if you need a ground lift.
GND PLANE"
Three pads here. These are, from the left to right, PWR GND, GND PLANE in board, AUDIO GND. These three should probably always be bridged.
"+16V BUS" + "-16V BUS" +"+48V BUS"When bridged the voltages will be distributed across the boards. Look at the graphics. If not bridged you can use these bussed pads for something else.
To bridge either insert a component leg cut-off and solder that, or just add enough solder the the pads so that it flows together. Either way works. You could of course also add pin headers and jumpers if you want it nice and tidy.
30€ each.
50€ / pair.
80€ / 4 boards.
