A quick, not very scientific comparison.
I finished a second dual channel tube mic pre based in Ian Thompson-Bell's Twin Line Amp.
I usually use the OEP A187A15C but had the idea to try something different, in this case the UTM 2572. Both are in the
same price range but the UTM is much bigger and not PCB mountable, at least not in a 1 RU case.
Both TX are similar regarding THD+N as well as Noise floor, slight advantage for the UTM maybe. We are talking about decimal points here.
Frequency response. First measured at mic level:
Both are fine.
Next line level:
Two things: in the TLA topology the OEP has a HF roll off that starts a bit too early for my taste. The UTM has a clear
ringing. This can be tamed with a 560pF strapped across the secondaries.
Conclusion: since the device is intended as a mic pre there is no reason to change the horse.
![tla2.jpg](https://proxy.imagearchive.com/a92/a92621f44adb7952ae74edac8843b4aa.jpg)
![oep%20utm%20mic.jpg](https://proxy.imagearchive.com/35f/35f30c447c2a914165a5b85b5e15cf8c.jpg)
Both are fine.
Next line level:
![oep%20utm%20line.jpg](https://proxy.imagearchive.com/f6d/f6d2e36974edee5d235b9a13235057f4.jpg)
