Battery Voltage Step Up Circuits?
« on: March 03, 2006, 06:20:07 PM »
I was looking for a way to step say 9 volts from a battery up to say 18 volts or 3 volts up to 18 volts. Can anyone point me in th right direction. Current consumptoin of the device is max 5mA. Is there a range of mini inverter units :?:
Vikki(uk) :thumb:
CJ
« Reply #1 on: March 03, 2006, 06:49:09 PM »
dc to dc converters
mouser
digikey
Frank's- www.mif.pg.gda.pl/homepages/frank/vs.html
Guitar- http://tdsl.duncanamps.com/schematics.php
EZ81
« Reply #2 on: March 03, 2006, 07:22:24 PM »
hagtech
« Reply #3 on: March 04, 2006, 01:39:53 AM »
Easy circuit is to use an ICL7662 in voltage doubling mode.  Look for the U3 chip in this circuit.  You can skip the 100 ohms, but it helps to reduce output noise spikes.  Voltage at C10 is roughly double the input.
jh :wink:
Jim Hagerman
Hagerman Technology LLC - making audio fun again
mnats
Re: Battery Voltage Step Up Circuits?
« Reply #4 on: March 04, 2006, 03:12:54 AM »
...or 3 volts up to 18 volts.
http://www.siliconchip.com.au/cms/A_100886/article.html
Don't let the block diagram fool you - it's dead easy to build and takes up less room than a 9V battery (without the 2 AA cells to power it, of course). Sells as a kit here in Oz:
LINK
« Reply #5 on: March 04, 2006, 06:19:35 PM »
Hi thanks everyone, time to do some experimenting.
Vikki(uk) :grin:
Tekay
« Reply #6 on: March 05, 2006, 10:42:27 AM »
Vikki you can also check out Traco DC/DC converters, think you can get them from both RS and Farnell
Thomas "TK" Kristiansson
"The Sound Is In The Iron"
www.vintagedesign.se  www.tkaudio.se
mikeyB
« Reply #7 on: March 06, 2006, 08:07:08 AM »
Yeah,just used a traco in a purepath repair - built in linear +/-/48 supply and used a traco 24 to 5v (400m/a) for the leds - works a treat - very low ripple - tried the unit without traco(no leds) and can't here or see any detrement in using the traco - incredibly compact as well - size of a 1cm high 24 pin DIL!
making better music!
Last post June 23, 2004, 06:42:18 PM
by jaotao
Last post September 08, 2004, 04:58:33 PM
by neilium
Last post September 09, 2004, 08:18:55 AM
by zebra50
Last post October 20, 2004, 02:59:30 AM
by
Last post November 02, 2005, 07:21:55 PM
by JW
