For Sale PROJECT SUPPLIES: ACTIVE DEVICES, CONNECTORS, POTS, PROJECT CASES, TRANSFORMERS, WIRE, and more! GroupDIY pricing.
Try FreeCad. As it says, its free and very very good! Quite a bit of tutorial VDOs also on YouTube
>> I use SolidWorks here-at-home myself!!! It was $7,600!!! OUCH!!!
Maybe you could send me your Fusion files??? I have found that "Parasolid" files translate extremely well between CAD programs. They output as -- .x_b (binary) and as .x_t (ASCII) -- files. Otherwise, it's usually either IGS/IGES or STP/STEP files.
I used to work with Altium for schematic and PCB design and the mechanical designer in the office was on SolidWorks.
Both these softwares are in the 10K$ scale, but now that I am retired, I still do projects for fun and was missing Altium dearly and never used any CAD for mechanical design before.
This friend tried FreeCad and found it very capable, and it is used by many engineers and scientists, and myself, I found that KiCad for schema/PCB is very good.
But some features are missing or ackwards to use, so I understand why these softwares are not used in a pro environment, but for basement/kitchen engineers these are tremendous tools! And for free!
Active Devices:
Coming Soon - Diodes, LEDS, Transistors, Opamps, Voltage Regualtors and more.
Connectors:​
  • Switchcraft PXCST Female XLR and 1/4" Combo Jack. $4.00 Each plus shipping.​
Gold-plated contacts, straight pc pin. 98 available.
Project Cases:​
  • Hammond 1456PK4WHCWW sloped cases with solid walnut sides. Build a Mini mixer... mic pre... you name it. $55 each or $90 for 2 plus shipping.
We have 8 6 of these available - if anyone has any use for them let me know. These are all brand new in their original package (cardboard wrapped with shrink over that)... well 7 are still wrapped. These are nice-sized units (total width of about 14 inches) with a vented bottom and back, solid walnut sides (yes, real solid walnut). The bottom is steel, the top is aluminum. These could be great for many projects discussed here in GroupDIY. The PDF with all the details is attached. They are about 4-6 pounds each.
  • Hammond 1458VC4 - Vented Case excellent for external power supplies, mic pre, etc. $40 each plus shipping.​
Roughly 6 x 6 x 4" externally. We have about a dozen of these on hand. They are REALLY nice little cases. We can laser engrave these here and/or machine/drill your cutouts/holes if it helps.
  • Hammond 1458D5 - Non-Vented Case excellent for external power supplies, mic pre, module rack, etc. $40 each plus shipping.​
Roughly 8 x 8 x 5" externally. We have about 5 of these. Nice cases. We can laser engrave these here and/or machine/drill your cutouts/holes if it helps.
  • Hammond 1458G5B - Non-Vented Case excellent for external power supplies, mic pre, module rack, etc. $45 each plus shipping.​
Roughly 10 x 8 x 5" externally. We have about 8 of these. Nice cases. We can laser engrave these here and/or machine/drill your cutouts/holes if it helps.
  • Hammond 1590B - Die-Cast Stomp box enclosure, an industry standard for a reason. $5 each plus shipping.​
Roughly 4.4 x 2.4 x 1.2" externally. About 100 90 on hand, I am not counting all of those now. Bare aluminum We can machine/drill your cutouts/holes if it helps.
  • Bud CU-124-G - Grey Die-Cast Stomp Box enclosure - Same size as the Hammond 1590. $6 Each plus shipping​
Roughly 4.4 x 2.4 x 1.2" externally. About 80 67 on hand. We can laser engrave these here and/or machine/drill your cutouts/holes if it helps.
  • Bud CN-5706 - Die-Cast Stomp box enclosure. $8 each plus shipping.​
Roughly 4.7 x 3.9 x 1.4" externally. About 100 51 remaining on hand. Bare aluminum. We can machine/drill your cutouts/holes if it helps.
  • Hammond 1590XXOR - Die Cast Enclosure. Orange. $10.00 each plus shipping​
Roughly 5.7 x 4.7 x 1.5" externally. About 100 94 on hand. Facory Orange. We can machine/drill your cutouts/holes, or laser engrave if it helps.
Transformers (Audio)​
Transformers (Power)​
  • Hammond 262B6 - 120V Pri: 120V, 6.3V secondary $15 Each plus shipping​
This is the physical size of an Altec 1566 transformer, FWIW. 11 9 available.
Wire:​
  • 14AWG (2.5mm) SIAF Wire - White - 100M (328 ft). $85 Each plus shipping​
  • 14AWG (2.5mm) SIAF Wire - White - 20 feet. $11 Each plus shipping​
High Temperature -60 to +180 degree C. 500V tinned copper flexible core silicone jacket. 3.5mm overall diameter.
  • 16AWG (1.5mm) SIAF Wire - White - 100M (328 ft). $85 Each plus shipping​
  • 16AWG (1.5mm) SIAF Wire - White - 20 feet. $11 Each plus shipping​
High Temperature -60 to +180 degree C. 500V tinned copper flexible core silicone jacket. 2.8mm overall diameter.
  • 18AWG (1mm) Equipment Wire - Green/Yellow - 100M spool (328 ft). $30 Each plus shipping​
  • 18AWG (1mm) Equipment Wire - Green/Yellow - 20 feet. $3.75 Each plus shipping​
1500 Volt tinned copper wire. Stranding is 0.2mm x 32. PVC Jacket. 2.52mm overall diameter.
  • 19AWG (0.75mm) Equipment Wire - Brown - 100M spool (328 ft). $25 Each plus shipping​
  • 19AWG (0.75mm) Equipment Wire - Brown - 20 feet. $3.75 Each plus shipping​
1000 Volt tinned copper wire. Stranding is 0.2mm x 24. PVC Jacket. 2.0mm overall diameter.
  • 20AWG (0.50mm) Equipment Wire - Pink - 100M spool (328 ft). $25 Each plus shipping​
  • 20AWG (0.50mm) Equipment Wire - Pink - 20 feet. $3.75 Each plus shipping​
1000 Volt tinned copper wire. Stranding is 0.2mm x 16. PVC Jacket. 2.0mm overall diameter.
More coming, check back soon!​
Feel free to ask questions.
Thanks and take care,
-Tony
amp-haus
