Normally I would post this in one of the design forums(hopefully it doesn't get moved!)
I'm designing a passive EQ ala Pultec.
I'm working with 6 bands of cut and boost "Hi" and "low" respectively, that is 6 hi cut, 6 low cut, 6 hi boost and 6 low boost.
I would like to ask; "If you had to pick 6, what are the frequency points that you audio engineers would want? e.g. 2,3,5,8,12,16K? etc... for each boost/cut band? Would they be the same?Like 2K on the boost and cut. Or, would it be 2K on the boost and 3K on the cut? that type thing.
Thank you all!
Thank you all!
