[quote author="PRR"]> making a dedicated amp maybe with tubes
For 1-buck headphones? Make darn sure they work GOOD before you go insane building an amp. Electrostats are not, in my opinion, that wonderful. And the electrets are generally considered inferior. And I know the electrets can be ruined with test-tones.
> So you think they need a good voltage swing to drive them? what 30v 50v 100v
400V RMS for many STAX, 800V RMS for the better-grade STAX. Sony did not break any laws of physics so they will be similar.
You are over-thinking the polarization. These are 2-wire electrets! You can't short the polarization.[/quote]
Would a Stax SRD-7 and the Sony ECR-400 be compatible?
The connectors are different, could be for other than propritary reasons.
Normal headphones have normal connectors because it is hard to blow up earth connecting a set to some amp. But the electrostatics may not be that fun to connect between brands.
My Sony ECR-400 was bought in the past two weeks and just arrived this evening. Sounds great. Did cost me 42 GBP plus shipping. But they were complete, 1x Headphones + 1x Amplifier (called Headphone Adapter).
There are DIY projects on the web for Electrostatic designs but I would read some of the litterature on the subject before venturing into practical projects.
Over on http://www.audiocircuit.com/ you click on
Headphones, Electrostaic, Projects and also EPH-AR, for a projects with nice pictures.
Mikkel
