1k Log Pot as a Pad
hoodun
Active member
Can I just use a dual 1k log pot to pad a 600 ohm input? Would I need any added resistors.
This is for the AM16.
It will be an AM-16 mic pre amp. JLM uses a 1k log pot with a resistor as a variable input on these. Leaving the output open to 600 ohms. At least as far as I can tell. I'm trying to figure out what that resistor value is.
I also may put a 10k log on the output with just a switched pad on the input. Everyone seems to have there own way of doing this... Not sure what is the best.
Is the the Langevin AM-16 or the old AM16 by JLM - I am afraid I am not familiar with either. On JLMs site they have a variable pad kit that uses a dual 1k log pot to make a balanced fader which they say can be used with their old AM16 module. Is that the sort of thing  you are considering?
Its the original Langevin, not the JLM. I am confused by which is better and the positive and negatives of going either way. I always thought a 600ohm pot on the output is best. Then I read that a 1k variable pot on the input is best. Is there any reason why one is better than the other? I'm thinking with a variable pad on the input would give a more consistent sound since you will always be driving the input to its maximum? The JLM versino only gives -20db of variable control. So a -20db pad is still needed. I dont think you can give -40db of control. at least not with a 1k potentiometer.
OK. The Langevin AM-16 is a transformer in, transformer out mic pre with 45dB fixed gain. If you plan to use it as a mic pre then to vary the overall gain it is probably best to use a variable pad at the input. This will maintain headroom.
A dual 1K log pot wired as a balanced attenuator should work fine.
