Rob Flinn said:use the Bournes pots because they are really good quality. Split a rubber grommet in half & put it on the shaft behind the knob so it creates a bit of friction between the knob & the panel.
fragletrollet said:Rob Flinn said:use the Bournes pots because they are really good quality. Split a rubber grommet in half & put it on the shaft behind the knob so it creates a bit of friction between the knob & the panel.
Well so I tried this, and imo it didn`t work very well. Quite hard to get the same feel on all the pots.
Now that CAPI is almost empty of these:
http://capi-gear.com/catalog/product_info.php?cPath=50_131&products_id=227
anybody knows where I can get these from? Both Mouser and Digi-key has a 500 minimum order, as they are non-stocked. Or maybe I should go for the OMEG`s, as buckethead did.
I want that smoooth feeling when turning pots. The Bourns in the BOM are way too light to turn, and I want this mixer to shine 8)
fragletrollet said:Anyone?
lukas said:Look on my post, there is schematic ACA(i think is correct), and mute switch.
Rocinante said:Im just saying something for you to try but iirc wouldn't a switch in that scenario be used like a rheostat?
+ or - in and Ground out then?
Just an idea.
