ruffrecords said:Now I am beginning to recover from my recent operation
ruffrecords said:kambo said:just curiosity
attached ...
It is an artefact. The noise spectrum varies continuously with little peaks like that all over the place. I used four averages to smooth thinks out a little but deoending on when you take the snap shot you get little peaks like that.
Here is the same amplifier this time powered by AC heaters. No mistaking the peaks on this one!!!
ian
Edit: Note that with the standard A or IEC filters for noise measurements, this 50Hz peak drops by about 20dB.
ruffrecords said:And lastly for comparison, the same amplifier with the gain turned right down so what you see now is just the noise and the hum from the output stage. Largest 50Hz peak is now -75dBu.
Deepdark said:And this one is with gain close, so your listening to the internal output noise, right? What I understand is that the hum get higher when you push the gain up, right? -75dBu means about -85dBfs, or so, right?
ruffrecords said:Deepdark said:And this one is with gain close, so your listening to the internal output noise, right? What I understand is that the hum get higher when you push the gain up, right? -75dBu means about -85dBfs, or so, right?
I think the input was shorted but even with 150 ohms it is very much the same. The figures are in dBu. What that means in dBFS depends on your converters.
The hum definitely gets higher as the gain gets higher whic means some hum must be getting into the input tube.
kambo said:can we say
50hz sine_wave at -60 dbu / 0.7 mv (RMS),
would be close your main hum noise ? (minus the harmonics of it)
Deepdark said:ruffrecords said:Deepdark said:And this one is with gain close, so your listening to the internal output noise, right? What I understand is that the hum get higher when you push the gain up, right? -75dBu means about -85dBfs, or so, right?
Gain at max, if it was on my system, would looks like -75dBfs and gain close would be about 90dBfs or so. In. Normal mixing situation, you would not hear any noise, even with gain at max, compared to the audio signal. The hum at the input could be the heater traces EMI polluting the nearest tube pins, like the grid?
I made an test with my LA2A and rewired the heaters by connecting V1 last, instead of the beginning of the chain. It help quiet a bit but when gain is to max, then hum get higher. Before I change the heater routing, i hadn't this rising hum, but the EMI was worsed at V1, so general hum performance. Maybe the heaters now are passing near an sensible part and get hit with full EMI.
All my LN stuff is in boxes hand carved from solid Unobtainium by virgins. I never have trouble with hum because of this.ruffrecords said:Now, although the unit in the above post was completely enclosed in an aluminium cassette, I had not made an electrical connection from the cassette (chassis) to 0V.
ruffrecords said:Now, although the unit in the above post was completely enclosed in an aluminium cassette, I had not made an electrical connection from the cassette (chassis) to 0V. So I did this and repeated the test which you can see in the attached spectrum. As you can see the 50Hz component has dropped by 10dB and the harmonics have changed.
Deepdark said:This is impressive result. DC heater looks to work well here
ruffrecords said:Deepdark said:This is impressive result. DC heater looks to work well here
it is good, but not as good as it could be. Attached is a noise plot of the original EZTube version of the Classic PCB at minimum gain (its output stage is a mu-follower just like the gain make up in the EQ) in the same test rack using the same external dc power supply. Here you can see there is a tiny 50Hz component at -120dBFs (about -113dBu) and no sign of any other harmonics. The only difference in the case of the EQ is that there are some unscreened Carnhill inductors in there which may be picking up a bit of hum from outside. Just shows you cannot be too carefull when it comes to hum.
The OT is generally less critical than IT or EQ inductors (or wiring layout for that matter), but nevertheless driving the OT with a low impedance circuit is very important.Deepdark said:Unscreened output yransformer must picked a bit, too. I know cinemag offer their inductors in a schielded can. I remember building some pultec and using them. I guess their is some circuit design more prone to pick up noise than other, ?
