sr1200
I'd call you very brave for etching your own DOA. They're small enough to begin with with a LOT of holes that need to be drilled on a 1" x 1" board.
The DOA (discrete operational amplifier).1. the schematic that is on here has an IC in it before the output transformer? this isnt on me pcb's what is it, and is there a another schematic without this IC?
Depends on how you hook up the 1+1:6.45+6.45 primary windings and secondary windings of your OEP A262A3 (ordered with mu metal shielding as separate accesoir). Parts values of R6, R7/RC and C8 are related.2. when using the OEP transformer for the input what should be the changes in the other values?
The GSSL has no separate balancing board. No need for the current drive ability of a DOA with following THAT1606/1646, DRV134/135 or SSM2142 balanced line driver chip. A single opamp (maybe on an adapter board to plug in to the DOA sockets) might do as well. YMMV.3. im planning on using a balancing board as per the Gssl instead of transformer and changes or can this go straight in? also thinking of designing a pcb that will fit in the output transformer space.
Sure. THAT1510/1512, INA103/163/217, SSM2017/2019 with surrounding circuit.4. if a balancing board can be used in replacement for the output transformer can something else similar be use for the input transformer?
Balanced line drivers come with fixed gain of +6dB, need power supply, are missing galvanic insulation, ... Just look up the parts datasheet. Your output transformer has 3 secondary windings, so can be wired for a 1:1, 1:2 or 1:3 stepup ratio. Standard wiring is a +6dB 1:2 stepup ratio, leaving a spare 1:1 winding that might be used for a VU meter (obviously showing half the level of your other +6dB combined output winding).Spencerleehorton said:Im interested in if you can use IC's that replicate transformers for the output transformer, what will be the difference
I'd trash this idea. This would be a complete transformerless mic preamp circuit, but with fixed gain, set for the input transformers stepup ratio to not mess up your frontpanel gain labeling, would need additional phantom blocking caps, clamping diodes, ...if this was also done in replacement of the input transformer, and having these to be able to slot in so if i wanted to change for OEP transformer i could, or if im able to have both and maybe switch them?
Ment to 'cheap and cheerful' supply two SSL 9k boards (different circuit with different voltage and current requirement, to be read in context with the mains transformer in front). For four Access-312 preamps, you'd at least need to increase some cap values in the voltage doubler section. I'd use a TL783 for the +48V part.The PSU pcb I ment was the SSL 9k psu sorry got confused there, this will be ok right?
Probably input in series, output in series for a 1:6.45 stepup ratio (from Jorge's schematic I'd try R6 24K-33K, R7 47K, C8 220pF) orHow should i hook up the OEP A262A3?
yuppbest to get the mu metal can as well yes?
VU meter (singular and electro-mechanical device). You connect the meter across these winding ends with IIRC 3K9 resistor in between. A LED meter to mimic a VU meter is a different subject and depending on circuit doesn't need to occupy your spare winding, so you could use this aux.winding elsewhere (FI monitoring, send for psycedelic lightshow, ...).is the VU-1 and VU-2 connections for VU meters, if so would something need to be put before i connect them?
AFAIK the Access-312 pcb is layed out for a Cinemag CM-75101APC or a EdAnderson EA2622 (transformer with 8-pin housing). This transformer has two primary windings that can be wired in series or parallel for a 1:5 or 1:10 stepup ratio for the Cinemag or a 1:3.5 or 1:7 stepup ratio for the EA and a single secondary winding. The OEP (transformer with 9-pin housing and different pin order and meaning on secondary side) has two primary and two secondary windings, so these secondary windings can be hooked up in a series or parallel config as well (and you have to pick one option, else it won't work when leaving pins 6 and 7 for the other winding ends unconnected).Spencerleehorton said:I am wanting to use an input transformer (OEP A262A3) and use a balancing board option.
I have read what you have said and you say about using the OEP and im assuming you mean to use it as the input TFX but wire the output of it in different ways?
Unless you finaly decide, which parts you will use for your boards (different/additional chips might come with different max.supply rail voltages and will draw additional power), noone could seriously tell you. This will be a minor important part of all.Still unclear on what to do for the PSU as this is probably the most important part first of all.
For an impedance balanced output. You lose the +6dB from missing output transformer, so you might decide to use a DOA that allows for higher supply rail voltages for maybe usable increased headroom (the following stage will have max.input voltage limits). Increasing supply rail voltages is not neccessary/contraproductive with output transformer fitted in a stepup config. You cannot make these descisions without context to surrounding parts or requirements.also Jorge has emailed me an 2x 51R resistors, 2x 10K resistors and 2x 470uf/50V which i will try instead of the balancing board, sounds interesting.
Yepp. For DI/line mode you most likeley don't want a 1:12.9 but 12.9:1 ratio and make up the -22.2dB step down loss in the preamp.bieckmusic said:Thanks Harpo!! On their website I found the A262A3E, is that what you were referring to? 150 and 600 primary, secondaries are 6.25k and 25.k, so primary windings in parallel and secondary windings in series for DI mode, do you know the configuration for Mic mode...
With a not broken/shorted mic cable connected there is no DC through the winding. An applied phantom voltage with matched 6K81 resistors (same value is more important than absolute value) is common mode. If either XLR-pin2 or XLR-pin3 is shorted to phantom voltages 0V reference voltage in a broken mic cable, this isn't common mode anymore but 48V differential and there will be 7mA DC current flowing thru the winding. Same might happen if the 6K81 resistors power rating is not sufficient and you had connect a broken cable. This might kill your opamp/DOA as well from missing protection clamping (when you switch on phantom voltage with broken cable connected, opamps noninverting input sees 48V times transformers stepup ratio, far exceeding the opamps supply rail voltages. This switching on from 0V to +48V by definition isn't DC but AC, so the transformer will not block but reflect it to its secondary side).It says no D.C. through the windings, will the 48v phantom be destructive?
