arigy
Member
- Joined
- Mar 24, 2010
- Messages
- 7
Dear friends! As I noticed, analog summers are all based on current summing, in one way or another. Traditionally, we use a resistors as a current source, then ground them all via load resistor (passive summing) or use inverting opamp (active aka virtual earth summing). If we are talking of passive summing, the source resistors with Rload are forming a divider, which leads to substantial level drop, so we have to use output amplifier with high gain, bringing up noise.
But what if we will use active current sources instead of resistors, such as Howland Current Source (http://www.national.com/an/AN/AN-1515.pdf)? As these current sources are independent of Rload, the output voltage will be independent of channel number, so we'll only need unity gain buffer on output.
Keeping in mind internal trimmed resistors, we can make Howland Current Source of any Balanced Receiver, like SSM2141 or INA134 with just two precision resistors.
What's the drawbacks of this approach? I know there should be
