Another diode bridge compressor
I accidentally flipped the channels by having my L/R cables crossed
edit: I uploaded corrected version to the folder.
are you pushing it heavy?
I had the attack and release at fastest position, ratio at low and the compression meter needles were barely moving. Since the compression knee is fairly sharp and ratio pretty high even at lowest ratio pushing it heavy will quickly end up sounding way too compressed.
One thing I noticed in common with my proto is the ability to excite details in the upper range... But I m still using it in mono so can t really judge... Even at faster setting is not destroying the sound... Also not compressing the output is better than the original source... Better transients
Best
Richi
Always big cases, so spacious, just like nature in Finland, awe :)
Is that LEDs behind those VUs?
What does the Monacor LTR-110 add to the output sonically ? FQ response of that transformer looks quite flat on paper. Picked up a pair for cheap, but not sure worth implementing.
Also, pins 4 and 5 of that xfmr would be unused. Good for hooking up an LED indicator...? Any other use ?
And would hooking pin2 and / or pin7 to ground make much of a difference?
It's a quite small core, so it will probably start to saturate early; you can expect some 3rd-order THD.
It's a secondary output. You may use it as such or hook it to anything, as long as you don't load it unduly.
Compared to what? Certainly you can't drive the primary between 1 and 3 and ground pin 2. You could drive the primary between 2 and 3, for 6dB additional gain, but the frequency response may suffer because of the reduced coupling. Grounding pin 7 should make very little difference, but you would ruin CMRR.
Quite small xfmr (core) indeed. Not a huge fan of 3rd-order THD. Might still give it a try.
Sure don't need a secondary output for LED indicator. Any other hint what it could be used for ?
At high output levels there will be significant distortion at low frequencies with LTR-110. If I remember correctly I think I measured several % THD at 20 Hz at +20 dBu output level. When playing music through the compressor I can't hear a difference with or without the transformer.
Can the standalone diode bridge be retrofitted with this DC balancing ? Would different resistor values be needed ?
The extra winding might be used to make a negative impedance converter driver. That could improve the thd and bandwidth by quite a bit. But NIC drivers are very sensitive so a lot of experimenting and testing would be necessary to even see if it would work correctly and be stable. And even though it would only be a few parts, one would have to be a trimmer I think.
Or it could just be used for feedback which should also improve thd and bandwidth.
Do you suggest driving the bridge control current from two inverted sources?
If you do that, you have to remember that GR is directly related to the DC current, so if you use balanced control voltage sources, you have either to halve the voltage or (roughly) double the series resistors.
