I once had a stray kitten hanging out in my car port for a couple days mewing it's heart out. It finally figured out that I wasn't going to feed it, probably moved in next door. 8) Just like you never see cat skeletons up in trees, this one moved on and found food elsewhere.Gene Pink said:Yeah, I have the same neighbor, feeds all the feral cats. Looking at the shiny side of life, it has been 15 years since I have seen evidence of rodentia around here,
Yup, haven't seen mice or rats around for several years, I wish the cats would chase and catch all the squirrels still up in the trees. They are rodentia too IMO.
I had squirrels chew into my phone line up on the pole... the POTS still worked but DSL went intermittant. I had a hard time convincing Duleep in Bagalore that unplugging and resetting my modem didn't fix the DSL problem. If your phone line is bad how are we talking? ;D ;D ;Dwhen I had to rewire a chewed-through wiring harness under the hood on an International Harvester step van within biting reach of a nest. That may sound like an easy job until you realize that IH must have got a deal on green wire, every wire was green and numbered only on the ends. That took a while to ring out, but not too bad, all 1972 type stuff.
My 97 mustang wiring is a little flaky... I can't lock it which sets the built in burglar alarm because it spontaneously goes off in the middle of the night...turn signals are a little sketchy too. Some combination of cheap wiring and optimistic ECU software. I wasted a few hours looking for an intermittent door switch, didn't find it.
yup... been there... never saw a bloody stump, but heard some spectacular wake up screeches from under the hood. The smart ones wake up and book out when they hear you close the car door.Back up north, ever start your car on a cold morning, hear a screech/hiss, and see a cat that was sleeping under the warm hood run away with a bloody stump where there used to be a tail? Yeah people, it happens, don't "puss" out over it.
To invoke Schrödinger, we'd need to cover the bell jar with a black shroud so you can't see inside. I predict the cat would still be dead, but we have enough cats to try that too. 8)The experiment is inadequately controlled for only a single variable. Of course you can't hear the cat meow, after you evacuate the bell jar, but is it because there is no air to transmit the sound? or because the cat is dead? I suspect the experiment is only partially conclusive... (the cat will surely die and dead cats don't meow). ;D
I'm not sure, perhaps we should consult with Schrödinger about this. He would know what to do, or he wouldn't.
Gene
PS: My apologies to cat lovers, I wouldn't go out of my way to kill one, while I don't feed strays, cats, dogs, or politicians. If you do they will never leave you be.
