Another Project. Behringer ADA8000, Revision with Cirrus Logic
AUDIO FREQ
GDIY Supporter
US
So I got this from a friend, and I need to figure out hte capacitors in these areas. If anyone can help me out.
Trying to get this thing up and running so I can extend my I/O :)
I will recap the whole thing, because who knows how old these capacitors are.
Unless they're somehow fake, I think those are Panasonics. Blue sleeve would make them either SU (older general-purpose 85C), or M (newer general-purpose 85C).
Is the ADAT in/out done with V1401/2 chips?
I was asking, what values are they supposed to be? I think you are right, they are Panasonic with the M logo on them.
The ADAT I/O is indeed the V1401/2 chips.
Last time I looked into one of these, I had noted that there were a ton of 10uF/25V and 22uF/16V caps in there. Judging by the size, you can probably get away with just buying a bag of 22uF/25V caps and replacing everything (with the exception of the phantom blocking caps, of course).
This jives with the schematic posted above.
Are the phantom blocking caps the 47uf 50v's?
I tapped directly into the Wavefront chips balanced inputs ,
ditched the pre-amp board entirely ,
takes a load off the toroid transformer based psu in the original ada8000 , which had a tendency to fail ,especially with 110v primary connection .
I was thinking about doing this. Just disconnecting the front board completely and using the DA section only. Or using as a summing box with transformers.
Apollo Adat OUT > ada8000 > 600:600 Tamura output transformers > Apollo IN
