any chance you could share this schemo?gary o said:...also noticed a different schematic than I worked from with 290V Ht extra capacitors different resistors feeding threashold pots & a balances pot for ECC85 plates & couple other differences , gonna try these changes out too
Which "original circuit" are you referring to? The Altec, or the Chiswick schematic in the previous links?kambo said:i dont know if the pcb has some errors, but p2p is pretty easy for this....
and original circuit works fine....
mulletchuck said:diyfanatic, does the Schematic contain errors?
gary o said:2000 pound !!!!! may I ask what did you spend that amount on ?
I havent been following this PCB story I gather some bugger sold u PCBS that have errors.......Im sorry to hear that thats shitty......but moving on can you not fix or work around the errors, I recently point to pointed a mono version of this mainly from junk total cost prob 100 quid there not much to the circuit, in total labour I reckon it took less than a day, ok its not pretty and I made short cuts but it works great... now I no that I might tart it up a bit, as I did it as an experiment.
I wish you luck if I can help let me no.
