Attenuators - Calculations for making them
SLB
Active member
Australia
I have noticed that there are a lot of people asking about various types of attenuators, how to make them and what the values should be. I have attached the values and resistance curves for a 600r Bridged-T Attenuator. As you will see from the resistance curves you can't buy off the shelf pots. You have to get them custom made. Universal Audio gets them made by PEC.
  • 600r Bridged-T Attenuator Calculations.pdf
Because you can only add 1 attachment to a post I have attached the info for a 200r Bridged-T Attenuator. If you would like other impedance types just ask.
The 200r Attenuator is what is required for the EMI REDD47.
  • 200r Bridged-T Attenuator Calculations.pdf
welcome and thanks.
(you might revisit the 'Voltage Ratio' column for the correct values =power(10;(dB value / 20)) and fix the typo '200r' for 600 ohm in the headline)
Hi Harpo,
I don't understand what you mean by "=power(10;(dB value / 20)) " I used the formula in the attached file.
your 'Voltage Ratio' column is giving wrong numbers. (this is an attenuator, so voltage ratio K >=1)
same as =1/(10^(dB value/20)) if you like it better.
have a look at my version to get the idea.
edit: just added some other sheets to this excel file
edit2: .. and the next
I see what you are saying. The R1 and R2 values are right the voltage ratio column had the -1 subtracted from it so it was not technically the voltage ratio. It was the voltage ratio -1. I have fixed this miss leading bit up. Thanks for pointing it out.
I have updated the pdf files in the earlier posts and added the XL sheet.
Bridged-T Attenuator Calculator.xlsx
Regards,
Brezo
