Dimitree
- Joined
- Jul 26, 2011
- Messages
- 122
this is the analog front end that I'm going to use with a PCM4222 ADC (a fun project, not for a commercial product), that I draw with the help here on the forum and reading datasheets.
what I learn is that conventional balances input stage have poor real life CMRR even with slightly unbalanced source impedances,
hence the buffers in front of the 4-resistors diff-amp. I choose THAT 1286 because I had several of those already, I could have choose THAT 1200 (full InGenius solution) and avoid buffers, but those chips are more expensive and then I would have needed another opamp to provide the negative side to the ADC.
I want to expand this circuit with switchable input sensitivity, and also solve some doubts I had:
1) now it can handle +24dBu differential input, and (thanks to the -6dB configuration of THAT 1286 and R9/R10/R11) attenuate it that to 2V RMS (the ADC has 5.6vPP full scale input). I'd like to scale the input with some switchable options (probably with analog switches, or mechanical switches) like +12dBu, +18dBu, and so on.
What's the best approach to do this? One option I see is Figure 11 of THAT 1280 datasheet, just adding three resistors on the buffers to add gain when needed. Another option could be switching R10 with other values?
2) how is C8 calculated? if I switch R10 (question above) then I need to switch C8 too?
3) what is your suggestion for the input buffer impedance? I could be wrong, but reading the THAT InGenius explaination, the higher the value of the input resistors, the higher is the noise (that’s why a full InGenius approach would employ bootstrapping). So, is 1M still a good compromise that doesn't not degrade performances, or should I lower it? If so, how about the coupling caps value?
4) I noticed AD8273 and AD8279 by Analog Devices looks functionally similar to THAT 1286. The AD8279 employs higher value resistors..what's the consequence?
thanks!
thanks!
