Baxandall EQ questions
I want to create a tube pre-amp with a baxandall EQ. I've searched bits and pieces and came up with this design.
You can use this proven design for inspiration - an Ampeg B15n Portaflex bass amp.
If you want to feed an existing high-impedance instrument amp, the preamp is sufficient, if you want to play into a console or interface (or even lower impedances), you need a driver output, possibly a tube cathode follower with or without output transformer. Solid state is of course also possible.
Edit: Ampeg, not Apogee 😅
Thanks all!! This is great information. I can carry on with my project with confidence. When I'm finished I will share :)
It has indeed an internal little pre-amp already, powered by a 9V battery. It's a single transistor stage with output transformer.
I was planning to keep that the way it is. But now you mention it, I will experiment with higher gain and removing this stage.
The schematic of the Apogee B15n Portaflex bass amp looks very similar to my plans. I will definitely use it as a reference (or copy it completely). Thanks!
I'm going to build it from a Hammond percussion amp, so I would like to keep it simple so that everything fits in there.
I am also a great fan of single knob things. So I'm going to combine the bass and treble control in one stepped rotary switch + a by-pass switch. So although the 3 band would be more flexible, I'm not going to use it. Thanks for the idea anyway!
The manufacturer is of course Ampeg and not Apogee. I have corrected my original (stupid) mistake. 😅 Sorry!
You may be disappointed because the pickups are low impedance and thus the solid-state preamp is probably best in terms of noise than a tube stage that is definitely better for high-impedance sources.
Yes.
But there is a trick - the pot installed on the guitar.
If is linear, the amp must have relatively low input impedance. Around 1/4 to 1/10 of the pot impedance will convert the linear pot to logarithmic.
If the pot is logarithmic, the amp must have high input impedance.
Here is an example:
Yes.
1Megohm input impedance has a very limited effect on the actual taper of a typical 250 or 500k volume pot..
Which is the case here.
