ddld
Member
Hi there. I built two VP28s, with two sets of opamps. One of the VP28s is working (and sounding glorious), the other is not passing any signal. I have verified that the opamps are good by swapping them around. I am somewhat new to analog electronics. After having built five kits of various vendors, this is the first time I'm running into a problem, so I could use a little help debugging the issue.
I'll try to be very specific about what I did so far:
- Set up a function generator to generate a sine wave at 400 Hz, 150 Ohm output impedance. At that load, I need to set it to 2.613 Vpp to measure 1.228 VRMS on the DMM.
- I hooked up the function generator output to pins 8 and 10 of my 500 series jig. With the DMM, I can verify that the voltage, when connected, is just a little bit below 1.228v.
I measure 41 mV at TP1, a maybe 1 mV at everything else. The signal indicator LED of the unit doesn't light up when I send in a signal, but it does when I measure TP1.
UPDATE: I meticulously reflowed the input transformer contacts, and now I measure a solid 112 mV at TP1. The other points are still completely zero though.
I've attached an overview of the unit. I've checked and reflowed all connections. I'm fairly confident that the soldering is of decent quality. I've also checked all the resistors against the other VP28 that works. I've built and populated them simultaneously, so it's unlikely (but not impossible) that this is a stupid component mixup.
I'd appreciate any suggestions on going forward. It would be particulary helpful for me to know what the test points mean, since there is no schematic as far as I can tell. I assumed TP1 was behind the input transformer, but I don't know where the others are in the path. This makes it hard to guess where to look.
Thanks in advance!
Thanks in advance!
