twentys7ven said:Hairball Audio said:twentys7ven said:Hairball Audio said:Then this is the correct thread.
Does the meter work in +4 or +8?
Get a good signal going through it...like at least 0dbu (0.775VAC) on the output. Does the meter react in +8 or +4?
Nope, not at all. Just fed it a signal and the meter won't budge at all regardless of how loud of a signal is passed through or what the meter is set to display.
Hmmmm. Sounds like a damaged meter maybe. You have the signal wire harness on there? (Metal Spades).
If those are the terminals underneath the meter then yep.
Jettison said:OK. Negative DC voltage is getting all the way to R7, which has a small drop across it, but not to the gate of Q1/R6.
Pulling Q1 and looking for ground...
Jettison said:Q1 is good and I got the Q bias set. Just had to fix a couple solder pads/traces.
I set the null too after a pad fix as well.
Now I'm stuck on the tracking adjust procedure-
On step 4 turning up the input only gets me 1vac at the output (attack off)
Also turning the compression on and of yields no change in output voltage. There is no compression happening.
I calibrated one last night and everything went great. When I started the second one, the q bias didn't seem to change the voltage at the output xlr. However I noticed when I adjusted the q bias the meter would change. Also the output control changed the voltage at the output xlr. Any suggestions on where I should begin searching? I checked all solder points and components.
seb121314 said:Hi,
i have a pair of these in revision D and i have the active stereo link in it. I have a problem to make them work in stereo, the one who receive the signal from the link have more gain reduction then the one who send. i try changing the cable and re calibrate the two but nothing changed.it's pretty problematic when i do parallel compression the stereo image change due to the difference of GR.
bye the way these are really cool product and fun to build !
Hxcplayer said:I know this isn't really an issue to post about and I know I am going to sound like a mega noob but, I was curious as to what the roles of capacitors C1, C7, C8, and C10 are?
If anybody can give a brief explanation as to how each of them affects the rest of the audio circuit would be great.
I can't find anything on the web that gives an explanation of what a capacitor does in an audio unit (aside from the caps in the power supply acting as reservoir caps to maintain current *correct me if im wrong*)
I will be trying out the orange drops soon for my rev. D so I figured it would be nice if I could understand what each capacitors is doing to the signal.
But just curious about the those specific ones i named earlier.
Hairball Audio said:Hxcplayer said:I know this isn't really an issue to post about and I know I am going to sound like a mega noob but, I was curious as to what the roles of capacitors C1, C7, C8, and C10 are?
They are coupling caps. The connect two sections of the circuit together and block unwanted DC from one section from moving to the next. Since they are in series with the signal and the audio passes through them they have noticeable impact on the sound.
Deeper:
http://diy.ecpaudio.com/p/some-notes-on-coupling-capacitors.html
Mike
Diamondj421 said:Hey guys,
Finished my 1176 Rev D build and am having trouble with the q bias calibration. I have everything set as recommended but turning R59 from max (CW) to its minimum only results in a -.5 Db change. Has anyone had/dealt with this problem before?
Hairball Audio said:Diamondj421 said:Hey guys,
What is the DC V range at pad 18 and then pad 7 (using chasis as common) as you rotate the Qbias?
Mike
Diamondj421 said:What is the DC V range at pad 18 and then pad 7 (using chasis as common) as you rotate the Qbias?
Mike
At pad 18 it reads 0 to -73.4 VDC and at pad 7 it's reading -1 to -71.8 VDC.
Hairball Audio said:That'a not really possible. Try gain and check your meter. Should be 0 to a couple volts negative.
You have -10VDC at that power supply test point right?
Diamondj421 said:So I have the DMM set to the 2V setting and pad 18 is reading 0 to -.092 and pad 7 is reading 0 to -.089. Am I still far off? Where is the power supply test point? This is all new to me. My Lola build was assemble and record.
