Can I add an LED to the Schoeps/Alice circuit ?
smikofficial
Member
Hi,guys !
I am studying about microphones.
Thank you for learning a lot from this amazing site.
I'm asking you a question because I have a question recently.
Usually, DIY microphones don't seem to have LEDs on them.
Can putting LEDs on the microphone have a bad effect on the sound quality?
Also, if you can put an LED in the Alice circuit, I want to know which part of the circuit you can add.
Thank you for reading it.
This can be done very easy here. You could replace the zener with a smaller value zener like 9v and add a led in series with this zener ( until you have reached the 12V again of the original zener value). As different color led have different voltage drop you would have to experinent a little here but 1V difference will not cause any issues.
If I connect it in series with the 9V zenor, is there no need to connect additional resistance? Normally, I knew that the driving voltage of the LED was 3V. I wonder if the voltage overload of the LED occurs when 9V is applied.
I was thinking of the same method actually, but without bothering changing the zener. Yes, most leds have a 2-3v voltage drop, but that's at the "usual" 20mA. At lower currents, that'll be somewhat lower (worst case 2.5v for a blue or white led), but the circuit won't mind being supplied with 14v instead of 12.
This is very simple. LED can be added to all power supply lines. It can work well only by connecting appropriate resistors in series. Of course, this will also bring a certain amount of noise, which is insignificant
There will be no noise added in this case as it will be series with the zener (a zener is much noisier then any LED), probably will be even less noisy if you would replace the zener with only LED's until you have the voltage you like.
You can use a jumper in case no LED is populated on the board (or an other diode to get a similar voltage drop).
Placing diodes in parallel is never a good idea as one will always dissipate all the current as the other will be doing nothing (unless you use ballancing resistors).
@Екатерина @Lampie519 @Khron
Thank you for your reply.
I'm using EasyEDA for simulation, so can I connect the LEDs in parallel?
When designing a PCB, I would like to design it with the pin of the LED as an option.
-Parallel
-Series
Both of them should work normally. I prefer parallel connection. The noise caused by series connection will be greater. More filter capacitors should be added nearby. I don't like to use Zener diodes here. Do you want to try resistance partial voltage here, and don't forget LED current-limiting resistors
capacitor and resistor ?
@Екатерина thanks for reply.
Example.. schematic
series resistor (current -limit)and parallel capacitor (filter)?
but I'm guessing that the current in that part is very low (below 10mA). If you connect the resistance, wouldn't there be less current?
Example.. schematic
The common power supply parameter is 48V30ma, but now most of them are only about 20ma. In order to work stably, the current consumed by led cannot be greater than 5maОдин вопрос..jpg
