Dr Gris said:Just a clarification.
I use external pads made from the info from the Uneeda-Audio link above when sending line level
to the pres. When racking them I also made a switchable pad in the rack (500R//169R).
The sweeps with pad on/off is this switchable pad (and of course the external line to mic pads,
since the sweeps are at line level)
I also implemented an interstage pot but I felt it sounded grittier and better (kick,snare) the more
I opend the pot, insted of blasting the first stage and turn the pot down.
This was for an obvious distortion effect. Thats why the AD clipped.
I would never change out the transformers, those are the biggest reason I bought originals insted of
building it from scratch with new parts.
The Edyne/Langevin are indeed push-pull.
I'll post some samples in the future.
Best
//M
emrr said:Inputs have 50k secondary which is typical of American tube gear before 1970. It's not an especially high ratio. Descriptives sound right. Measured distortion over around +2 DBM will be significant.
The Thord iron sounds quite a bit bigger that the UTC, while the UTC sounds more focused.
emrr said:Did we mention there are also Freed and UTC versions used as stock on the 6Q-1? None are off the shelf iron.
it comes in at around -83dBfs. not stellar noise performance but it seems to be usable
