dandeurloo
Here is a option. If you plan on using one of my cases. You can have the edcors shipped to me and I can ship the case and transformers to you to share shipping. I have done that for a number of guys.
frazzman said:Hi Sammas,
I'm from Oz as well, I had a similar dilemma... The postage direct from Edcor in the USA is ridiculously expensive but the price of the transformers are ridiculously cheap...
The transformers for this project cost me $10usd each + $50usd shopping so $90 all up, I think that will still come in cheaper than the carnhills ...
dandeurloo said:Here is a option. If you plan on using one of my cases. You can have the edcors shipped to me and I can ship the case and transformers to you to share shipping. I have done that for a number of guys.
salomonander said:hey
did anyone use the original utcs on this build? i need help with the pinouts. i have utc a10 and a24 and need to know how to hook them up. thanks!
ps: would it be smarter to mount them on the outside of the case (like back in the days) or inside? im wondering about shielding etc....
cayocosta said:It appears that the 1968 schematic illustrates the A-10 (input tranny) primary labeling inverted - with tranny pin 6 hot. Older schematics as well as photos of reissue units illustrate tranny pin 1 hot.
If I'm correct, then this is the way to wire the input for XLR pin 2 hot:
XLR input pin 2 --> barrier strip terminal 1 (optional) --> HA100X/A10 tranny pin 1 (primary) HOT input to tranny
XLR input pin 3 --> barrier strip terminal 5 (optional) --> HA100X/A10 tranny pin 6 (primary)
(My layout reflects this, and this supports the reissue manual's instructions to use barrier strip terminal 1 for hot)
Now, the output side is always illustrated the same way in all the schematics (without the XLR) - barrier strip terminal 10 to tranny output pin 1 hot. However, photos of the reissues (with XLR's) indicate that XLR pin 2 is wired to barrier strip 8 (pin 6 of the output transformer), which would reverse the polarity from the output tranny.
This is how (in photos) the reissue unit's output is wired for XLR pin 2 hot:
XLR output pin 2 --> barrier strip terminal 8 (optional) --> A24 tranny pin 6 (secondary)
XLR output pin 3 --> barrier strip terminal 0 (optional) --> A24 tranny pin 1 (secondary) HOT output from tranny
(My layout reflects this too, and this also supports the reissue manual's instructions to use barrier strip terminal 8 for hot)
But, the trouble here is that pin 6 of the output tranny secondary is not the hot side.
Has the signal's polarity been flipped by the time it gets to the output transformer primary, so that reversing the XLR connections puts the signal back in phase on the way out?
If so, then it makes sense.
Sorry if I'm pointing out the obvious but triple-check all the resistor values that are in the path to the meter. If it sounds like you're getting correct GR then something is going wrong between your sidechain and your meter.salomonander said:ok so i sorted most things out. the unit works, compresses and sounds gorgeous. but my meter doesn't show the correct values in GR mode. i can clearly hear more than 15-20db of reduction while the meter never adventures further than 3-4db of reduction. no matter what i set the gain reduction to. anyone have an idea where i can start the search? i did replace rX25 with a trim pot.
cheers
bernbrue said:Hi,
I would like to report my findings concerning oscillation. My input transformer is the original Sowter 1:4, Output is Edcor 10K/10K. I did the 25K pot 75K resistor mod for the input gain.
Background: My unit worked fine from the very beginning, except for the annoying 30kHz oscillation with higher gain settings causing meter pegging. I moved the output transformer farer away from the board and the xlr connectors which helped a bit. I consequently used moderate gain setting so that unity gain was almost achieved.
Today I tried various ideas to eleminate oscillation. I realized that the area around V1 and R11 (68K Feedback) is very touchy and that even moving my hand around V1 reduced oscillation a bit. CJ proposed to change the value of R11 in order to reduce negative feedback and gain. I finally put a 14K resistor in parallel to the existing 68K. That helped quite a lot but I still couldn´t crank up the gain to maximum without meter pegging.
Then I had a real "heureka" experience. The shielded wires for the gain reduction pot and gain pot were connected wrong, well not wrong but the shield was conducting signal and a red wire was meant to work as shield. What a silly mistake!!!! I rewired it and now I can set the gain pot to maximum without any oscillation at all. I measured the compressor with RMAA and the specs are more than convincing. With the paralleled negative Feedback resistor THD is 0,382 %. Not that bad. All other values including absolutely flat frequency response are excellent. I´m more than happy now with my Dual LA2a!!
People having these problems as well: CHECK YOUR WIRING (verify that shield is connected to ground!!!) and REDUCE FEEDBACK RESISTOR.
regards
Bernd
band_master said:getting 6.7vac across 3 and 4 but also getting 6.7vac across 4 and 5. Must be a short? will have to double-check heater wiring again.
