innercityman
3.6k resistors on meters.maybe wrong value resistor in series with the meter ?
on the la-2a the meter is just taking the unbuffered signal from the output.
If there is healthy audio signal on the output of the compressor there is nothing else that could be wrong except the wiring to the meter, the switch, the series resistor, or the meter itself.
regarding the hum you mentioned, the AC wiring from the power transformer should be kept as far away as possible from high impedance circuitry.
It seems from the photos both the mains wiring and the lamp supply are very close to the gain pot. Any noise picked up there will be amplified in the following stages.
The wiring to the limit/comp switch is also in the input grid circuit of the first amplifier stage, I believe on the original La-2a this wire is shielded.
It would help to have the mains switch on the side of the front panel. I have seen some commercial units using a shielded microphone cable for mains wiring going to the on/off switch in the center of the front panel.
Re checked connections and made some tests this morning... Meters work on output position but really tiny gain. When sending 1Khz sine wave at 0db left channel goes to -7db maximum on meter with gain pot fully open, right channel goes to -3db. Still no compression on both channels.
