LevinGuitar
- Joined
- Jun 13, 2019
- Messages
- 424
I'm repairing a small old Japanese (25w?) amp. It had a non working 50K pots, but after a small cleaning they are somewhat working again. Overall I would like to make it sound better.
1. It have a bit of noise (not an issue) that does not increment with the volume pot, where does it comes from so? I have replaced almost all caps but it did not make change about noise.
2. The spring reverb is too low, almost make no difference.
3. It sound too powerful and not so clean, distorts easily on lows (the speaker I guess is dying).
Looking for the datasheet of the LA4420 5.5W chip (there are two of them), I found that the circuit is almost the same as the datasheet of the chip.
For now I tried to ground the negative speaker lead to use only one chip as amplifier. It was a small improvement, and still powerful enough. The reverb is gone, I have to look how is wired into the circuit.
Any more ideas? To lower 17.7v to 13v as the datasheet main voltage would be nice I guess. Also should I try a 0.15uf speaker filter cap to ground as the datasheet have?
I find it an interesting amp as it's small, light, have a 12v dc imput (the battery compartment is missing in my sample) and two imputs so it can be a useful tool for casual gigs.
