k brown
One advantage is the availabliity of an inverted signal, if one should need it.
thank you for the clarification,
so now my question is, what are the advantages of using "active" impedance balanced output with an additional opamp (like the one I showed above) versus the simpler approach of using just the series build out resistor + its matched resistor on the undriven side?
I apologize for the unclearness of my questions,
what I wanted to ask is, considering those two approaches below, that can be used to add a "direct output" after a balanced receiver (for example the one proposed by Thor on post #24),
I was wondering what is the advantage of the first approach (the additional opamp in ground-sensing configuration) compared to the second approach with only two resistors. I assume the opamp approach introduces a noise penalty compared to the simple build out resistor, so there must be other advantages that I still haven't understand
thank you, I missed this point before, now it is clear. I'm sorry if I take too long to understand those topics, it's all quite new to me.As I pointed out, the first circuit actually provides CMMR when feeding an unbalanced input. If you know you are feeding a balanced input then you don't need it.
is this perhaps one of those designs? There is no output capacitor on the undriven side.I have seen some outputs which appeared as if the designer only partially understood the principle, such as having a matching resistor, but not including the output capacitor on the undriven side.
what puzzled me was that on the book, when talking about "zero impedance" outputs, he says: "The impedance-balancing resistor on the cold pin has been replaced by a link to match the near-zero output impedance at the hot pin."That output stage is a "Ground Sensing" configuration. It provides CMRR into an unbalanced input by adding the remote "Ground" into the signal transmitted. Well covered in Self's "Small Signal..." book. That version is also configured as a "Zero Impedance" output.
the 75 ohm resistors are the set points of voltage reference the zero crossing of the signal sees. The coupling capacitor provides a near zero output impedance while isolating the two signal reference voltages. When the output is shorted (tip to sleeve) or zero impedance load is applied, the 75 ohm resistors provide the critical loading for the op amp.thank you, I missed this point before, now it is clear. I'm sorry if I take too long to understand those topics, it's all quite new to me.
Instead here I see a 75R on the cold pin. Is that resistor needed again because of the "ground sensing" configuration?
Unfortunately on the book there are no examples of "zero impedance" output and "ground sensing" output combined, hence my doubts.
while browsing some old schematics, I noticed that the Soundcraft 8000 uses the same "double inverted" configuration (at least to my novice eyes) that we were discussing before, although with a slight more complex gain control network (well, more complex for me)
I also have another question..what would it be the best approach (noise-wise) to add a direct output after this receiver? the goal is to send this direct output to an external audio interface for recording.
I think impedance balanced output with a pair of 75R resistors after the opamp would be enough (I don't think I need fully balanced output, the connection between the console and the audio interface are extremely short, so I think I can sacrifice CMRR here) but looking at other consoles I often see this approach:
WHAT??????Go screw yourself if your dumb British mind can't handle it. Alert Bitch
is this [ground sensing output] perhaps one of those designs?
The shown circuit works well but real world performance can be well below textbook.
and cost?We should still challenge the wisdom of these "textbook" circuits from the 1960's and 1970's in 2023. Many things have changed. Improvements are commonly possible.
One just needs to be clear what performance parameters we want to maximise, e.g. from low circuit complexity, low noise and high CMRR select any two, but not all three.
Thor
and cost?
can you lend me a dollah?Cost for DIY is immaterial.
more than I charged when I was still accepting work... Last century. [edit: I actually charged $100/hour so maybe we were in the same ballpark. ]I charge 500 USD per day for consultancy, that's the friendly rate. So 1 hour I spend on some DIY is worth at least 62.50 USD.
its all relative..Next to that almost all components cost pales.
I used to operate a kit company back in the 70s-80s. My kit company customers were very much influenced by cost.I have, since growing up in eastern Europe never considered DIY a way to save money.
My dream list these days does not include analog audio paths.It is a way to get what you really want from what you can get your grubby mitts on and which is simply not available (or silly lala land price).
Yup, it is hard to justify DIY for anything you can buy off the shelf.Mind you, in 2024 the mass production costs are down so much on stuff that would have been world leading 100 times over that would behave been the GOAT in 1995.
I personally hold my own phono preamp designs in pretty high regard. I escaped the audiophile market in the 80s because I did not perceive a correlation between performance and market success. While more than 10 years before your 1995 hypothetical, I got an accidental review in Stereophile magazine comparing my $150 phono preamp favorably to a Mark Levinson ($5K ?).As I remarked, a recent phono pre selling under 250 USD offers a performance and consistency that, in 1995 was not possible with a 5,000 USD phono with components hand selected by certified vestal virgin's.
I still have some gold plated phono jacks in my back lab , anybody interested?And I might suggest the actual realised margins on the 250 bux phono in percentages are greater than those of the 1995 5,000 USD phono, once everything is accounted for.
What is more, swapping relatively high quality passives and actives for the worst garbage barely lowers the cost, as the majority is elsewhere.
Thor
Yes, please send over. I could put to really good use. Had a talk with my dentist. Will need a cap soon...I still have some gold plated phono jacks in my back lab , anybody interested?
