paulcheeba
- Joined
- Mar 29, 2017
- Messages
- 206
Have you guys seen the new version of that body with the E and the slot. Still looks too short though. There are no measurements. Looks a little more authentic.
I don't know why, it blocks my access to the producthttps://www.aliexpress.com/item/1005006469418125.html?spm=a2g0n.productlist.0.0.26ff29afkVnFTb&browser_id=6da7a948cf7a4d14bfc94e3b429c1907&aff_platform=msite&m_page_id=rfkhqdxtacavrppp18d4f24c0bd211d823f723f922&gclid=&pdp_npi=4%40dis%21GBP%2140.10%2140.10%21%21%2149.50%2149.50%21%40211b600917064298251973081e9a79%2112000037309162161%21sea%21UK%210%21AB&algo_pvid=ea625a6b-a21b-4edb-b4b9-38b56510e962View attachment 121334
The link doesn't work for me either, but this link does. Nice body.I don't know why, it blocks my access to the product
I took a chance and ordered a pair. When they arrive I’ll post pics and dimensions.The color looks a little more accurate on this new one. Has anyone verified that it's a similar build/dimensions to the yellower one?
I have tried to make a schematic of the Kingkorg with "switch omni" C12 with a 6S6BV point to point pcb with 3U audio transformer. Could you guys take a look at it and tell me if i did it well. Thank you. BestI used these, removed the plastic and snuggled them in the holes i made. I cut the upper part in half.
Capsule front direct to grid (0v), backplate 60v, rear variable via psu.
Here's a sketch i used for build. Never meant to share it, i just drew in one night at work based on the originals, and added external pattern control.
Edit:
I added 120Meg and 15nF filter before HiZ pattern control resistor due to some low end buzz.
What does R6 and C3 (1000 pf) do? Neither is needed for omni, just connect the rear diaphragm to the front to get omni.I have tried to make a schematic of the Kingkorg with "switch omni" C12 with a 6S6BV point to point pcb with 3U audio transformer. Could you guys take a look at it and tell me if i did it well.
There is a 1nF in Khron's schematic
There is a 1nF in Kingkorg schematic, i would like to understand where it is placed and why.
