Thanks Ian,
i might implement a 10k stepped attenuator to prevent crackles. C2 can also be jumpered if you're just using a mic input transformer, right? Can you tell I'm a big fan of taking caps out of the signal path?
Best ,
M.
[/quote
There is no reason to suppose a stepped attenuator would be any less susceptible to crackles than a regular pot. However, the chances of it happening are small so I suggest you try it and see. It is easy enough to put the cap back in circuit if you get crackles.
You can definitely jumper C2 for a mic pre. I also jumpered it when I built one as a DI with no ill effects.
I am not sure why you are keen to remove caps from the signal path. In this design, their minor sonic signature pales into insignificance compared to that of the tubes, but it is your build so go for it.
