that's right, back in action,
a pair of 6L6 tubes in this amp, and a 12" speaker, gonna need something in between me thinks,
but this OPT thinks it is an incense burner, every time you crank the Variac past 60 volts AC, the the 3 amp current meter needle starts dancing around like a skeleton on top of a Jimmy Swaggart confessional booth. emitting a fine aroma of baked enamel and burnt cardboard.
replace it with the same thing oh hell no. this is a small town. everybody knows everyone else. if an amp repair blows up onstage, my rep takes a hit. and it might even be that i might be at the same show now how is that going to feel?
run for the exit, that's how.so we rewind it to bulletproof specs, but first we need the turns and structure. so we do a tear down.
this guy right here, with the EBL AA batts charging in the background which is a story in itself. How do you get 1.5 volts from a 4.2 Li-Ion cell? internal circuit, that's how. Trip me out, looks like a normal cell, i hope they don't explode like those vape pipe batts.
ok back to this, EIA code says 606, Schumacher?
![d1.JPG d1.JPG](https://cdn.imagearchive.com/groupdiy/data/attachments/39/39699-b62e4b4e7f82fcaff748ab76eebf2693.jpg)
