Filtek MK3 -6db drop when engaged
andia
GDIY Supporter
Hello!
I have a filtek mk3 eq here that i'm racking up. the eq seems to work fine, the problem is that the volume drops -6db when I engage it. Does anybody have an idea what could cause that drop in volume?
thank you very much,
andi
hey thomas, all lines are balanced. the eq has a "bypass-switch" and as soon as I flip this switch to "eq on" the volume drops...
thank you
Junction said:
sounds like you are losing one leg of the balanced input or balanced output when you engage it
Exactly what I was thinking of-a 6dB drop nearly always implies a switch from balanced to unbalanced.
Good luck, ;)
Udo.
