Hi all...
Me and a couple of friends of mine sat down to do some "living room recordings" and we used all the mics we had and after a while we could hear some strange sounds and started to track down the source.
The sound is a bit hard to describe but it sounds like something being fried in a pan... "fffrrsss - ffrr- ssssrf" and so on (I hope the description make some sense)
The preamps and compressors and EQ's are all home-brew DIY stuff so an obvious reaction was that i could be something wrong with those but after some highly irritating coupling back and forth showed that the noise came from some of the condenser mics (As we could understand).
The mics I am referring to is a "Rode NT2-A" when the "directional switch" is set to Figure 8... no noise otherwise and the other mics are the Line CM3.
It might be said that other mics like Neumann KM184 coupled to the same type of preamps and compressors worked just fine for hours without any noise what so ever.
So... I would really like some hints on what this could be to be able to solve the mystery.
/John
/John
