gar2520 build thread
just for the record, although chungers build thread is spectacular, this does NOT show the values of the blue ceramic caps(the 2 yellows don't matter, are of equal value), you NEED the build doc's to orient those parts correctly on the 2520 and 1731, you need to ask for them at purchase.
T
I just built a GAR2520. I am a bit concerned that I have solder bridges between caps CD1, CD2 and the mill max pins for +V, C, -V and O.  They are so close together!!
I remember reading somewhere that this is not important and I just wanted to ask anyone who knows if this is true.
I tested the op-amp in a previously built VP26 and it worked. Should I worry ?
Hi, I'm building my first gar2520 and have a little problem. How do I determine which pine of Q5 go in which holes? From looking at pictures I'm pretty sure the way it goes but want to be positive. Thanks.
Thank you very much Gary. Those higher resolution pics(vs the ones in the PDF) help a lot. Much appreciated.
A short while later, I'm done. Gotta do one more and then the VP28 will be complete.
Hi there,
i recently built 4 of the gar2520s and successfully built 3 however my 4th is giving me some issues. I stupidly managed to mix up q7 and q8 and also r3 and r2 (long night soldering). After unsuccessfully testing it i realised my mistake and rectified it. After testing again r11 and r12 have burnt out.
Any ideas as to what could be causing the issue (other than my stupidity)
Regards,
Joe
Hi Joe... welcome to DIY
Don't feel stupid.. this is a very common mistake.  You are not the first
and won't be the last.
The output transistors don't like to be reversed and draw lots of current thru R11,12 when they are.
If you got Q7,8 back in the right holes try a new set of R11,12 and  you just might luck out.
4 times out of 5 this is all you need to do.
Best of luck
GARY
Many thanks for the reply Gary, i'll swap them out and give it another shot. I have some some of your 1731s on the way from capi. I'll make sure to triple check the components this time  :)
may have a solder bridge btwn r12 and tyhe outmill max.... are they supposed to be connected?
thx
s
thx
s
Yes,there's a trace you can see on the bottom side of the unpopulated pcb in the build manual,all good.
Best regards,
Udo.. ;)
Hey guys,
Just built a vp26 and a gar2525,...inserted into my lunch box and pfft smoke.  Powered down looked at the op amp and R11 and R12 are burnt looking.  Admittedly this is my first kit, but I was extremely careful and triple checked my work,...any ideas?
BudCarroll said:
Hey guys,
Hmmmmm......maybe look 4 posts back (#149)?
Udo ;)
P.S.:Welcome to the forum!
kante1603 said:
BudCarroll said:
Hey guys,
Udo ;)
Face palm,...switched the transistors and r11,12 still metered well,.......put it back in and whammo, my first Api pre amp kit sounds thick and meaty and awesome.  Looks like I've got a new addiction.
Cheers and glad to be here.  Thanks or the help.
Most of us did funny things when we started to diy.
Cool you got it sorted.
Best to swap out the both resistors too,even if measuring o.k. at the moment they might go bad one day once they look burnt.
Just a precaution and easy to reach.
Best regards and have fun,
Udo.
BudCarroll said:
kante1603 said:
BudCarroll said:
Hey guys,
Udo ;)
Bud..  Glad you got her working!!  Enjoy :)
BTW... This is one of the reasons that R11,12 are 1/2 watters ;)
You still will want to check all the transistors and diodes. Google "transistor diode check" or something along those lines and you'll find instructions on how to check them with your DMM.  I've managed to save a couple of DIY2520s like this, found the damaged transistors without having to remove them first.
