gar381
NOTICE OF PART CHANGE 10/5/23
Had to happen sometime... The pnp BC560C has been out of production
for some time now and my current supply of NOS Fairchild BC560Cs
that I have been using for last 3 years is running very low. I will be using
the remainder of my supply for only for the matched pnp input pairs for the
garOA10 and gar918.
I knew this day was coming so I have auditioned many possibilities.
From now on I will only be using..
BC557C mouser # 637-BC557C in the following positions...
gar2520 Q6, Q9.
gar1731 Q3, Q4
garAM10 Q1,Q5,Q6,Q7
garOA10 Q2, Q3, Q5, Q7, Q9
gar918 Q3, Q4
Note that these are all on tape and will just drop in place to the silk
just like the original BC560C
Gary
The Build PDF manual is good but here a few notes that might make the kit
A little less confusing.....
1) The little bag with the Millmax pins also contains Q1 and Q2 which are BC560C Matched Pair.
NOTE: This matched pair of transistors are different transistors than my other gar kits (2520, 1731)
and are not interchangeable.
2) The small bag of 3 transistors labeled Q5,Q6,Q7 are BC550C
3) The tape strip with 2 transistors are Q3,Q4 BC560C
See Page 6 of the manual for location
4) The little bag of caps..
The tan ones are CD1, CD2.
The blue ones.. see page 4 of the assembly manual
for value and location.
5) Please meter the resistors to determine value. See page 7 of the
manual for value and location.
6) There are 12 diodes in this build. Make sure the band on the diodes(cathode)
goes in the circles on the silkscreen. Note.. All diode pads on the PCB are
square. No other pads on the pcb are square. See page 5 of the manual.
7) After assembly PLEASE double check for unwanted solder bridges
on the Bottom of the PCB. See page 9 of the manual and make
SHURE THAT on the top of the PCB that no component lead wires
are touching each other.
8) When inserting your new DOA into the millmax sockets of
a module, Please insert straight down and not at an angle.
DO NOT push down on the component parts but use the edges
of the DOAs PCB. Remove DOAs the same way. Pull straight up
from the edges of the PCB and not at an angle.
9) Never insert a DOA or a module with the power on.
10) HAVE FUN !!
A pdf download of the manual can be found here:
Classic Audio Products, Inc.
GARY
garOA10 and gar918.
gar2520 Q6, Q9.
gar1731 Q3, Q4
garAM10 Q1,Q5,Q6,Q7
gar918 Q3, Q4
Gary
10) HAVE FUN !!
GARY
