jilski
Member
- Joined
- Sep 16, 2015
- Messages
- 22
Hey people,
I've read that great article about connecting grounds and star ground systems on the Rane website and built a little project, a parallel high-shelf filter similar in concept to the kush audio clariphonic.
Well, I've had this thing in use for a while and everything seems nice, except for one weird thing: When I screw the metal case together and screw it to the rack rails, I get that loud 60hz hum. As soon as the unit is on a table or if I don't really fasten all the screws in the enclosure, it works flawlessly.
Here's a picture of the unit open:
The white daisy chain at the pins 1 of the xlr connectors leads to the bottom left corner of the circuit board, which is the star ground center. Both the power supply ground and the audio ground connect there (and only there). However, on the picture, I did not connect that to the chassis. Theres that extra pin on the xlr sockets that Im using and the Rane paper suggested not to connect that to anything, so I didnt.
Since I thought that might be the problem, I tried connecting the same ground to chassis, but depending on where I connected it, to one of the screws of the xlr connector, or to a switch that has contact with the chassis, the hum gets a bit better, or worse, but it comes back as soon as I screw everything together so the different panels connect to each other.
I know this might be hard to debug, but maybe I'm missing some essential info here or something I'd like this unit to be working flawless, even if I screw it together proper and tight... right now half of the screws are loose and it won't hum.
