G
Guest
Guest
Sorry to post yet another ssl thread, but I couldn't find this info in the others.
I've got both boards mostly buil but there are a few details I'm unsure of:
1. There are two resistors right next to the 5534's that are marked 1K*. Why is there the asteric? I used 2K instead....do I need to unsolder those and replace with 1K resistors?
2. Off board transformer mounting: Ack, which wires go where? Also, the pcb says that if you're mounting off-board, you should add an extra bridge rectifier (I think that's what it is). I've been checking out pictures of completed SSLs with off-board transformers, but don't see any with a second bridge rectifier. What am I missing?
3. On/Off and Bypass switches: The pcb layout shows how to mount all that on ONE switch instead of 2. I think everyone used 2 switches (or buttons).....how did you wire them?
4. What kind of fuses should I get to go with the IEC (digikey Q201-ND) ? The spec sheet suggests 5x20mm, but I don't know which of those I ought to get.
I think that's it. I'm sure when I find out the answers to these things I'll realize it was obvious...
