[email protected]
Member
- Joined
- Jan 31, 2021
- Messages
- 8
About 2 weeks ago I noticed a new guitar amplifier buzz in my studio. I have since tried multiple amp & guitar combinations and they all have this nasty buzz. We have dirty power in my area so I've been using a Furman P2400 AR & IT for balanced power or a Tripplite isolation transformer. This setup has been working great for the last 4 years, then 2 weeks ago this buzz started. Occasionally an amp will pick up a very faint radio signal too.
From what I understand, I shouldn't be getting any sort of power line interference with balanced power so I'm not sure what to look for next. Any ideas what could be causing a buzz when I'm using balanced power?
The buzz seems to be roughly around 1khz. It does go away when I turn down the guitar. I have moved the guitar all around the room and the buzz does not change like regular guitar buzz.
There are no power lines or anything obvious that could be causing enough EMF/RFI that would cause this buzz. I have disconnected everything one the circuit other than the guitar amp and the buzz is still there.
