Cqwet Dbdfte
- Joined
- Oct 2, 2023
- Messages
- 405
Maxing out on plate voltage spec, atypical in the 6V6, may not be conducive to max lifespan.
sort of…outputting a couple of KW, and generate the "tone" in that stomp box to the input.
Probably already been done.
With all the environmental BS affecting manufacturing of any sort (especially in the US), quality and reliability is out the window. I suggest going to Ebay and getting ruggedized tubes such as JAN (Joint Army Navy) 6V6's built to a mil spec, 5751's in lieu of 12AX7's, etc. You are out of luck with EL34's. The only suggestion I have is to operate those vertical only. Some AM broadcast transmitters in the 1 to 5 kw range used EL34's as drivers for high power tetrodes (i.e. 4-400A, 4-1000A etc.); the EL34's would short due to sagging screens, etc. with the tubes operated horizontally. Since there was space available to use a socket adapter and operate the tubes vertically, the tube life increased substantially. This may also work with other power tubes in particular.If both 6V6's failed from mechanical shock at the same time, the amp may have been dropped.
Shock protection is a possibility, vibration maybe not so much of an issue, tubes were used in WW2 aircraft. Good easy to grip handles on equipment could help.
What brand tubes failed?
CJ...even the Mullards shorted out prematurely, especially if horizontally mounted in an amp. You are right about the NOS GE or RCA black plate 6L6GC's. I like the old JAN tubes myself....I have seen a few amps where the screen voltage is actually higher than the plate voltage, a filter choke is usually about 100 ohms and screens might have 5 ma running through them so v drop through choke might be a paltry 1 volt at idle , if the dcr of the opt is a couple hundreds ohms then the v drop might be 30 ma x 200 = 6 volts so the screens will be 5 volts higher. But thus has been posted upstream so I be redundant. Not all amps use screen resistors BTW.
I use to pay $3.50 a piece for black plate RCA 6L6GC but not any more.
So changing tubes was no big deal back in the day. At today's prices of 50 bucks for a soviet piece of junk it is no wonder that people only replace them when they fail. But we get 50 bucks plus parts for a typical service job so it is wiser to change tubes when you notice the tone slipping a bit.
You will have to change a JJ 6L6 about tens times quicker than a NOS GE or RCA black plate and your tone will also suck with the JJ tubes but people don't realize this unless they have used NO'S tubes in their amps.
All the rock stars used up all the good stuff, replacing tubes after every show with Mullard metal base EL34's, shame on you ZZ Top Led Zeppelin and Van Halen, Iommj gets a free pass just because,
Are they? Or as I like to say they are different. I have great sounding examples of both with tubes and with class D.Stop using tubes, use those class-D amps!
Sooo much better!
