It only "sounds" like it. Actually it's only 50% efficiency. "Transfer" is a deceptive term. The accurate description is "maximum power theorem", which has been insisdiously transformed in "maximum transfer theorem". Anyway "maximum" should not be read as "optimum".Maximum power transfer sounds like it is the most efficient case.
There is no "given amount of power". Power delivered by the source depends on the load. Most of the sources in audio are voltage sources with an internal impedance. When the load is high compared to the source Z, current is small, as is power. When the load is small, most of the energy is lost in the source impedance. There is a point where power delivered to the load is maximum, when Zs=Zl.I’m thinking about for a given amount of power.
This is assuming that the source can deliver enough current in all conditions. In practice the active stages are often limited by their own drive capability, or the power supply, or a dedicated protection system.
That is true.As the source impedance goes down and the load impedance goes up there is less current transfer and more voltage transfer.
See above.For a given amount of power.
Partially true. Less voltage transfer, yes. Current transfer is debatable, since current in the load is equal to current delivered by the source, current transfer is always 100%.As source impedance goes up and load impedance goes down there is more current transfer and less voltage transfer.
