Just THAT - preamp (Pre Grinder)
Gustav
DK
This is a simple pre based on the THAT1512/1646 combo.
I have built a handful of 1 channel versions and a single 8 channel, and the circuit has performed very well in all applications so far.
I hope these will work for self etch, in case anyone is interested.
https://pcbgrinder.com/download/Pre_Grinder_doc.pdf
The High pass frequency can be set by changing C21, and thats about it.
Just wanted to share.
Gustav
Thanks.  Have had these ics hanging around for some time. I either got them as samples (mail)or acquired them at an AES convention,don't remember which.
sonolink said:
Hi
What kind of sound do these preamps have?
I would say detailed and open, and they are not a clone of anything.
It's just a simple board, which is easy to build, and the schematic is almost identical to THATS own implementation notes.
Gustav
Nice!
C21 is cap A/B on the components overlay, right? And what value did you use?
Also some small suggestions:
- maybe include some text in the self-etch file? this way it will be 100% clear which way is up
- add the component numbers to the parts overlay?
- add a bom
Might be overkill but an external filter option would be great. I'm thinking of combining this with the Harrison filter board (minus the (de-)balancing chips). Is using the C21 pads all that's needed in combination with a DPDT-switch?
Thanks for this!
Nele said:
One more thing:
Include PCB-dimensions. I etched these from the pdf and they are too small!  :eek:
So sorry about the scale being off. When I printed the output to PDF and sent the PDF to my own printer, it came out in the correct scale, so I hoped that would be universal. I will look into it next week and change the files, so they are correct scale if I can figure out how  - and Ill also add the dimensions.
The rest is up to you or anyone else who might find use for it - and adding a Harrison Ford filter to this would be out of touch with the philosophy behind doing this. I tried to do a board to learn something basic about PCB and circuit design with a simple circuit, I tried to make plenty of room on the board and large pads for a beginner, and i hoped it would sound better than usual soundcard and interface stock preamps. I almost excluded the fixed high-pass, but it is just so damn useful.
I hope you get good result. I am still amazed at how good my rack of 8 sounds - and I am getting recordings in from people using my scattered 1 channel prototypes that are gorgeous. Sound was the parameter i was most worried about, and the chips must be great, cuz I have no idea what I'm doing half the time - and I will not be adding any bells and whistles. I would rather move on to something else :)
Gustav
Hi Gustav,
I double-checked and in the pdf the pcb is about 120 mm long. If I resize it to the correct ic-footprint it ends up around 142mm (width of copper), so there is some strangeness going on.
I noticed on your website that you sell parts-kits but no pcb's for this project. Is that a matter of time? I would be interested in a few. Home-etching is fine but drilling is a pain in the ass!
Corneel
Nele said:
Hi Gustav,
Corneel
Will check the self etch PDF and see if I can get a new one up in the correct scale :)
Gustav
HI Guys,
As per the printing the self etched file out there is normally some difference within the accurate output i have found. I think i adjusted my printer to 125% and this fitted ok. bit of a mine field but i used the pins off the IC's as a good guide.
have printed out 2 self etch'd boards just gotta drill and then give them a coating.
If i nickel plated the pcb after drilling would this be ok to solder or should i use something else?
regards
Spence.
Don't nickel plate - that is impossible to solder.
Better tin it, that's the common solution. Or leave it copper, that's the old-fashioned and simple solution.
Jakob E.
Hi folks,
These have been around for a while now.  I'd be keen to hear some reviews on the sound.  I'm looking for x8 cost effective clean pre's.  are they based on or close to a commercial product?
burglar said:
Hi folks,
They are simply based on the THAT design notes for a clean, open preamp, and if you self etch, you can do this pretty cheaply and get preamps that a far beyond the usual interface preamps.
I havent included footprints for alternative caps (Wima 6,8uF) but....Note that the input caps are in parallel, and you can add up any caps to get the values with a little twisting, bending and slight of hand.
If you want more than just a few preamps, you can do your own basic layout from the THAT design notes. It is a very nice learning experience.
Gustav
Gustav
Hi.
I am new to this forum, which I came across a couple of days ago. Sorry if this is not the right thread, but I suppose it is. I have been playing in bands for some 40 odd years, and have always been "the guy with the soldering iron", so I know how to solder, and I have some basic knowledge of electronics.
I think of buying two complete kits from PCB-grinder and build a 2 channel version of this pre-amp. I guess that is what you did in your second picture.
I have a 1U 19" case lying around, which is not deep enough to mount the PCBs front to back like you do in the 8 ch. version. They will have to be turned 90 degrees.
Will there be any problems, not having the gain potentiometer and the switches for phantom power and low-cut soldered directly to the board, and instead connect them via short wires? Should I use screened cable for the potentiometer?
For convenience I want the mic-inputs on the front, but as they seem to be connected with wires anyway, I expect no problems here.
I also would like to put in an indicator-LED to show if phantom power is on, just to have a visual warning before plugging in some ribbon-mic. If I make the switch for phantom power a DPST, I could use half of it to turn on a LED connected between the rails of the 48V supply via a suitable resistor. Will this have any negative effects regarding a clean supply to the microphones?
And yes, I know, that the electrolytics for the power supply will have to be mounted off the PSU board.
Regards
Erik
I don't think there's any problem. Keeps the wires as short as possible and just twist them together.
You could use a DPDT switch with two seperate poles so you could also use the +15V powerline to switch the led and keep the 48V clean.
I don't think this is necessary. You will need a seperate PSU board, but Gustav's standard psu has room for the electrolytics.
Yes. But a 1unit rack is very low. ::)
Kind regards
Erik
erik_DK said:
Yes. But a 1unit rack is <b>very low</b>. ::)
It depends a bit on spacers and cap-height what value will fit. If too low an option would be to keep the leads on the caps long and bend them.
On the other hand I've built quite a lot of gear in 1U cases (neumann eq, ssl comp, forsell comp, nite eq etc) and never had any problems.
Corneel
