Its been a long time since I finished anything, actually this is my second LA2A and although it took longer in time span it actually was shorter in build time.
I was more confident and kept my wire length shorter than first build.
No problems whatsoever with this one. Worked from first turn on. I'm really happy.
I used UTC A10 and A24, 12AY7 for V1 and 100K for R9 and R13 as per CJ. All my PS caps were 40uf.
I did not use variable caps for C4 and C14 but rather fixed ones.
If I were to change anything it would be to put the Limiter response pot in the front panel. I'd also eliminate the stereo pot section. XFRs are OK but if I build anymore I will use Jensen, Cinemag or Sowter on input at least.
I think the controls are straight forward enough to not need any identification. I like it as is.
Thanks to CJ and Cayocosta.
jim
jim
