desol
- Joined
- Jun 20, 2005
- Messages
- 2,129
ppa said:here the drums:
http://home.teletu.it/APPSI/DRUM%20OVERHEAD%20%20MA1_1.wav
Short clip..?!
desol said:ppa said:here the drums:
Short clip..?!
okgb said:In case it wasn't obvious [ to me ] forgot the jumpers at the output transformer
the 2 solid white lines between via's , Preamp works and sounds pretty nice , Thanks Pier
anyone try different transformers ? [ other than api type ]
sr1200 said:Just a couple of notes for anyone looking to build these.
1) EASY EASY EASY build. (theres 1 errata on the board which is easily fixed in 2 seconds)
2) No hens teeth parts to find. Everything is pretty straight forward and easily procured.
Im going to be doing a bit of a shootout with the pres in my studio, both commercial units as well as DIY to (hopefully) show the tonal variations and responses of the various pres. Ill post here and have a new thread once its all together.
Initial tests of the unit are very interesting in a good way!
I'm planning on grabbing a couple in the next month or so and wanted to do this as well. Do you think it will physically fit where the di is?sr1200 said:Just used the MA-1 on a session this past week. Used it on part of the drum kit and am using it for a bass track tonight. My ONLY complaint (or should I say request) would be for there to be a output trim on this bad boy. I'd LOVE to saturate the hell out of this puppy and see what she can spit out. Im thinkin, perhaps I can get rid of the DI and put a T-Pad in there.
Winetree said:I have a pair of MA1s.
How do you wire the T-Pads?
