Spencerleehorton
700 turns on the primary will give you the same inductance as the original Neve mic input and will add 3 db input level, 1.4 v-rms means 2700 Gauss on a core that will handle 5000. That core you bought off evilbay has two errors on the spec page, 1)-49 Ni will handle 12 KGauss and 2)-if you do an inductance test, you will find that what he sold you is actually 80 Ni with a max level of 5 KG, however, you want 80 Ni for a mic input and 50/50 for line input,
So your saying that the lams I've got should be good with 5000 right?
I'm wanting to use this as a mic input transformer.
Regards
Spence.
Regards
Spence.
