Deepdark
Hi guys
For personnal knowledge and brain training, I was looking at the 1731 opamp schematic linked and I want to fully understand it. Here is what I analysed but their is some place where I 'm not sure what is going on.
Looking at the input. We have a first differential pair (Q1 and Q2) tied in a common emitter (source) so we amplify the differential between the input + and input -. The output signal at the collector is then reverse. R1, R3 and R4 are our current source.
Then, exiting the first stage, we enter another pair of transistor, Q3 and Q4, which their emitter are tied together, as well as their collector and R5 is the current source. The signal at the base of Q3 comes from the output of Q2 and teh signal at the base of Q4 comes from the output of Q1. Is that it? So what is the goal of R2 and C1? Some sort of filtering, or stabilizing frequency? Now, can we say this stage is configured as a common collector (drain)? So the signal is not reverse and, by the same, we should talk about a common mode instead of a differential mode??
Next step is where I struggle to understand what is going on. If the output signal of the second stage is effectively taken at the source, then the signal from Q3 split at R6, which is tied to V-, and go to the base (gate) of Q5. Q5 looks to operate in Common source mode so the signal taken at the drains should be phase reverse. The output then go to the gate of Q6, which is also tied with the output of Q4. Here the signal shouldn't be the same polarity, isn't it?
Q6 seems to be tied in common drain and it's output feed Q7 and Q7 then go to output? the D2 diodes are there to form a voltage reference, isn't it?
Q8 looks to be feed by the In-, which also connect to the output or R8. This entire part is a little obscure. Is it there to form a loop?
Thanks for your time
